Good morning!!!!
   / Good morning!!!! #24,241
57 with partly sunny Skies with 40 % chance of Rain later,with a high of 74.We have to run and do a little shopping Today.
   / Good morning!!!! #24,242
73 this morning and humid. Rain to the north but say it will build in here later. Headed to 85.
   / Good morning!!!! #24,243
dave1949.
I figured it out! You can't smell the Red Soxs from there. :laughing: Bottom of the AL East, 19.5 games behind.
OUCH
   / Good morning!!!! #24,244
69F and .33 inches rain since midnight. Looking a bit overcast right now.
Be safe
Have a great day
David Sent from my iPad Air using TractorByNet
   / Good morning!!!! #24,245
Threatened rain all day but never happened. Alternating sun and heavy, foggy clouds. High of 80F and sticky.
Worked on the field all day. Skipped lunch thinking I was going to get rained out. At least the last two hours were all seat time spreading 3" minus for a truck turn-around and getting the new tractor/walking lane across a drainage area. Off to town this evening to fill the diesel jugs.
   / Good morning!!!! #24,246
dave1949. I figured it out! You can't smell the Red Soxs from there. :laughing: Bottom of the AL East, 19.5 games behind. .......................................................................................................................................................... OUCH
Thomas, okay it is 2 to nothing Red Sox's ahead. This would be nice to see the Sox's sweep the Yankees this week.....
   / Good morning!!!! #24,247
2014-09-03, 0339
60 right now and a bit muggy. High of 78 today and clear weather.
   / Good morning!!!! #24,248
65F and partly cloudy here ... headed up to a high of 83 today ... then 87F on Thursday and 90F on Friday.
Looks like the next couple of days will be a good days to spend inside ... :laughing:
Apparently the laptop is going to cooperate long enough for me to get some TBN reading in, as well as a post or two.
Have to pick up a fresh cylinder of 75/25 @ Matheson today, as well as hit Philcap Electronics and see what they have in the way of resistors to repair the plaz ...
Got most of the wiring on the west side of the shop sorted out yesterday ... almost ready to put the cover on the main panel.
Probably swing by Harbor Freight and pick up the short set of SDS Max bits if they still have them on sale ... will cut off the ends on one or more of them and then weld up a couple of drivers (one for ground rods, and for t-posts) ...
   / Good morning!!!! #24,249
rswyan:
Should hopefully be about a $10 fix ... but it will require desoldering the old resistors off the PCB and soldering new ones on ... something I've never done before ...
It will pay to get a low wattage iron. Very fine braided copper wire dipped in flux will soak up melted solder making it easy to remove the resistor wires and leave a clean hole in the PCB. Hold the fluxed copper braided wire down on the solder joint and apply the iron on top of the braid. Move the braided wire to a clean section as needed. Be gentle and don't overheat.
If you don't have fine braided copper:
Desoldering Braid & Wick | Quick Braid, Sea Braid, One-Step | Easy Braid Co.
Dave,
Thanks - great tip !
I've scoped out some YouTube videos on doing this and they mentioned a solder pump, which I don't have ...
I've got some short scraps of Cobra X-Flex 00 battery cable though that should fit the bill nicely I would think ... I believe it's around 1250 strands (turns out it's 1330 strands) ... it's almost like hair ...
:thumbsup:
   / Good morning!!!! #24,250
I managed to get the stand for the tubing bender/roller built. Had to clean up the plate as it had gotten a little crusty ...
I tried to align the top and bottom plates largely by eye, but I tried to verify it by holding a straight against the two plates and then checking it for vertical/plumb on two ends of the edge with a level before I tacked it up ... came out pretty close I think:
Mini-Excavator Heavy Duty Weed, Brush, and Rock Rake (New/Unused) (A59225)
Mini-Excavator...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
2018 Elgin Broom Badger Sweeper, Kubota Turbo Diesel Engine, High Dump, Dual Tilted Gutter Brooms... (A59076)
2018 Elgin Broom...
Fencing (A56859)
Fencing (A56859)
(4) CAMARO 5 LUG WHEELS & 245/50R16 97H TIRES (A54757)
(4) CAMARO 5 LUG...
2012 International ProStar T/A Day Cab Truck Tractor (A56858)
2012 International...
