Tire Leak
   / Tire Leak #11
get the portable tank. you'll never find a leak of 1 lb per 33 hours.
   / Tire Leak #12
If you can't find the leak with soapy water or windex, then take it to the shop and have them remount the tire. Maybe the rim needs cleaned up or new valve stem. Cheaper than the alternatives IMO.
   / Tire Leak #13
My wife has the same problem on her Ford Escape. One time she got a nail in the tire. Removed the nail and plugged that. 6 months later both front tires started to lose air pressure. This time I found the valve stem rubber was cracked. I replaced both valve stems. Now they've both started leaking again. This time it's leaking the bead is leaking around the magnesium rims so I have to dismount them, clean the rims and put liquid tire seal on the rims before remounting and balancing. Fortunately I have the tools to do this.
I suspect since your tires have a slow leak they are also leaking around the bead. The soapy water will find it. You may have to look close to see the tiny bubbles.
   / Tire Leak #14
We put many tubes in tubeless tires without an issue. Remember back when all tires had tubes? Many years back when steel belted radials first came out, a puncture in the steel belt area just about always leaked with a plug after a few miles the steel belts cut into the plug. The fix was a patch on the inside or a tube.
i've had tubes in tons of things.. but nowadays..if it runs on the road.. it's only in trailer tires.. not drive or steering axles..
   / Tire Leak #15
i hate mag rims. my wife had a lincoln mark viii and it constantly had metal flaking on the insides of the rims. I couldn't keep enough bead sealer on it to make it worthwhile...
   / Tire Leak #16
Another possibility (although very rare) is that it is actually the wheel that is leaking. Alloy wheels are made by a casting process and can occasionally have a pinhole leak in the casting.
Locating those is difficult. About the only way that works for sure is to submerge the entire wheel and tire in water the trace the bubbles.
Fixing that type of leak isn't actually that hard. A coat of paint or rubberized sealer sprayed on the inside of the wheel will normally do it.
   / Tire Leak #17
Not a fix by any means as all the fixes have been outlined above, but I heartily recommend the portable tank. No fun stringing together every air hose you can find and still be three or four feet shy.
   / Tire Leak #18
Another vote for portable air tank. Did you try some slime. You could also inflate it to 60psi or so and the leak may become more apparent.
   / Tire Leak
Thanks for all the suggestions.
I pumped the tire up to 60lbs or so and had it covered in a tub with soapy water and could not find the leak anywhere, treads, bead, or valve stem. The garage did the same thing and couldn't find a leak either. I put on a different value stem cap the other day just to try. I'll check the pressure again this weekend.
Remounting the tire is probably a good idea. The last time I got tires the garage (sears I think) wouldn't replace the valve stems. They said they were something special and they didn't have them. The car is an 08 Suzuki SX4 hatchback, all stock, nothing fancy. The value stem is a silverish piece of metal of some type.
I am leaning toward the portable air tank. I can also use it to fill the tires in my bike and tractor when the kids are asleep and I don't want to wake them with the noise of the air compressor firing up.
   / Tire Leak #20
Sounds like it has a TPMS on it, which is special valve stems. And possibly dealer only.
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2013 Ford Escape SUV (A50324)
2013 Ford Escape...
2012 RAM 5500 (A52472)
2018 Volkswagen Jetta Sedan (A50324)
2018 Volkswagen...
Toro Mower (A50324)
Toro Mower (A50324)
