First minor issue with my new 3016
   / First minor issue with my new 3016 #1
oldpilgrim
Elite Member
SE Ma
2014 Mahindra 3016HST
I've been using my new tractor for about a month and have about 20 hours on it. Everything is fine with the tractor itself but an issue has come up with the BH.
The BH was fine until yesterday when it started making a whistling wssssshhh sound thru the hydraulics. It's particularly loud when swinging the boom left-right or raising or lowering the main boom arm. In other words whenever the left joy stick is used it akes the loud sound. It doesn't seem to have the power it should either.
It is slightly audible when using the right stick but is not consistent. The noise comes and goes.
It sounds like a relief valve is partially hung up. Is there a valve for each stick/motion or just one for the whole hydraulic system on the hoe?
I disconnected the hose connections from the tractor and after I reconnected the lines, I 'exercised' the all the cylinders , but it made no difference.
If it's not something easy to do, it will have to go back to the dealer, but I'd like to avoid that if possible.
Any idea what it could be?
   / First minor issue with my new 3016 #2
Do you have a knobie on the hoe control panel to slow down the swing..?? [ my 595 hoe has one ]. You could check if that valve got turned down some.... Don't know much about your setup, but if you have to lock a hyd lever to get power full time to the hoe, you might check that it is being fully held to open up the flow. I think my 595 has an inline pressure valve in one of the hoses that hook up to the tractor.... maybe a filter, too.... [ ??? ] Good luck, and if you find out what it is, please pass on the knowledge...!! :)
   / First minor issue with my new 3016 #3
My BH has a lever in the cab to allow me to reverse the flow or, in the neutral position, cut the flow entirely. Is it possible you have the same, and the lever is in the wrong position? :confused3:
I have a knob to control the flow to the 3pt but I'm not aware of anything for the BH, but I'll look.
   / First minor issue with my new 3016 #5
I'm assuming the BH hydraulics connect via remote quick disconnects. If so, there must be a lever to disconnect the pressure to the QD fittings, otherwise you would never get the lines reconnected.
Dunno about the lever, but it does have the qd's. Today I disconnected them forthe first time after I shut off the engine, and worked the control levers...had no issues disconecting. Then I reconnected with no issues even after running the tractor first.
   / First minor issue with my new 3016 #7
Is it possible that you reversed the lines when you reconnected them?
No, the problem existed before I disconnected them for the very first time since I got the machine. The problem started after about a half dozen times of use after I got it new. The problem did not exist when I first got it. I didn't disconnect it until the issue arose. I'e read where sometimes disconnecting and then reconnecting is the first thing to try when hydro problems arise.
   / First minor issue with my new 3016 #9
Read the distructions for your hoe and tractor, could be something simple (on mine the 3-point lever has *got* to be all the way down or, according to the manual, damage may occur).
bumper
   / First minor issue with my new 3016 #10
Another thing to check is the fluid level, strange things can happen when the hydraulic levels are low.
   / First minor issue with my new 3016 #11
check fluid levels for sure.
Read the manuals, checked the fluids, no help.
I did discover that if I run the engine at faster than 1200 rpms, it doesn't do it....well duh!
   / First minor issue with my new 3016 #13
Correct, the manual for my 2615 say to never operate at under 1500 rpm.
   / First minor issue with my new 3016 #14
Not really knowing anything about this subject BUT why would you operate the BH under 2000 rpms anyway ? What would you be digging with the low pressure level ?
Please, I am not criticizing, just a newbie and wondering ?
   / First minor issue with my new 3016 #15
Scrambler,
I cant speak for OP, but i know a lot of guys operate at a lower RPM to slow down the movements of the BH, thus making it less "Snappy"
-J
yup. makes it less snappy and has about all the power I've needed so far. I'm running it at about 2000 now just so I don't have to listen to the noise. Ive traded BH noise for engine noise....but I'm getting better with the BH 'snappiness". I'd rather neither noise, but it's only a small matter in the scheme of things. :)
   / First minor issue with my new 3016 #17
Scrambler,
-J
I too ran at the lower speed when I first got my SC2450 but found that the better digging at 2000 (+) took away a lot of the "not digging properly problems".
I understand what you are saying but learn to control the swing and higher rpms results in a better BH experience.
Ltr
   / First minor issue with my new 3016 #18
One more thing I forgot to mention... when using lower rpms, the engine has the possibility of seating (breaking in) the ring too low and when you decide to bring up the rpms you may crack a ring.
After breaking period at prescribed rpms run the rpms up to a decent level, 2000 - 2500, to seat the ring high.
Just my opinion from a long history of automotive engines.
   / First minor issue with my new 3016 #19
Ltr
Scrambler,
I personally do not have a backhoe on my machine.... but, I do operate at sub 2k rpm when using my fel and (non pto) 3pt implements. I cannot speak for anyone's tractor except my own, but i have power to spare, even at 1700rpm. And running it at the lower RPM also decreases wear and tear as well as my fuel consumption.
-J
   / First minor issue with my new 3016 #20
Scrambler,
-J
The engine developers the required horse power at a given rpm.
Each implement requires a certain rpm to operate properly.
Properly operating implements equal proper horse power.
So yes, use the rpm necessary to get the performance you need but using a FEL is not the same as the BH as far as oil pressure/rpms needed.
Please, let me state all of this is based on my opinions, operator with more experience than me know better than I but to a point higher rpm related to better performance.
S/A Utility Trailer (A59231)
S/A Utility...
2019 Ford Transit Connect XL Cargo Van (A59230)
2019 Ford Transit...
UNUSED FUTURE BC63-57" HYD BRUSH CUTTER (A60432)
UNUSED FUTURE...
2017 Autocar Xpeditor T/A Heil V-161 Front Loader Garbage Truck (A59230)
2017 Autocar...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
