Ford tractor leaking coolant (pics)
   / Ford tractor leaking coolant (pics)
I think you are correct.
Is there anything I should know or look for when taking it off to replace the o-rings? Is there a shut off valve for the fluid or is it just going to all drain out? Anything I should know about replacing the hydraulic fluid?
Thanks
I cleaned up the area and took some more before and after pics. Do you guys still think its the o-rings? Its power steering fluid correct? and how hard is it to replace those parts or should I just take it to a shop? Its only leaking from that one spot
Thanks
Before
After
   / Ford tractor leaking coolant (pics) #14
It looks like you'd just drop the bottom lines off, undo the valve and drop it straight down. Doesn't look like much, but I bet it would be a couple of hundred at the dealer! I guess it would depend on your confidence level, and your wallet!
   / Ford tractor leaking coolant (pics) #15
It also looks like water contamination in the hydraulic fluid. I'd change it and filter too.
The oring change looks simple, give it a rip. Plenty here to guide you if you get stuck.
I ended up driving it to the hydraulic shop just up the road and they replaced all the o-rings and now its good to go. Cost me $120. Thanks everyone
Well guys the leak returned a few weeks ago. Should I even bother replacing the o-rings again or do I need a whole new priority flow valve unit?
   / Ford tractor leaking coolant (pics) #18
Just curious, have you priced a new valve?
   / Ford tractor leaking coolant (pics) #19
depends... are the areas the orings seat pitted?
was it loose?
was the wrong oring material used and they disolved?
4 of the frame bolts that go into the engine were loose. After tightening them down the leak slowed way down. It still leaks but very very little, a drop every few minutes. I think if I replace the o-rings again and with the bolts tight I should be ok? Thoughts?
2007 Ford Taurus SE Sedan (A51694)
2007 Ford Taurus...
1270 (A50490)
1270 (A50490)
KUBOTA M7-132 (A53084)
Kubota Salt-Spreader (A52384)
Kubota...
2018 INTERNATIONAL LT625 (A53843)
2018 INTERNATIONAL...
2019 Autocar ACX Xpeditor T/A EZ Pack Front Loader Garbage Truck (A51692)
2019 Autocar ACX...
