Ford tractor leaking coolant (pics)
   / Ford tractor leaking coolant (pics)
I think you are correct.
Is there anything I should know or look for when taking it off to replace the o-rings? Is there a shut off valve for the fluid or is it just going to all drain out? Anything I should know about replacing the hydraulic fluid?
Thanks
I cleaned up the area and took some more before and after pics. Do you guys still think its the o-rings? Its power steering fluid correct? and how hard is it to replace those parts or should I just take it to a shop? Its only leaking from that one spot
Thanks
Before
After
   / Ford tractor leaking coolant (pics) #14
It looks like you'd just drop the bottom lines off, undo the valve and drop it straight down. Doesn't look like much, but I bet it would be a couple of hundred at the dealer! I guess it would depend on your confidence level, and your wallet!
   / Ford tractor leaking coolant (pics) #15
It also looks like water contamination in the hydraulic fluid. I'd change it and filter too.
The oring change looks simple, give it a rip. Plenty here to guide you if you get stuck.
I ended up driving it to the hydraulic shop just up the road and they replaced all the o-rings and now its good to go. Cost me $120. Thanks everyone
Well guys the leak returned a few weeks ago. Should I even bother replacing the o-rings again or do I need a whole new priority flow valve unit?
   / Ford tractor leaking coolant (pics) #18
Just curious, have you priced a new valve?
   / Ford tractor leaking coolant (pics) #19
depends... are the areas the orings seat pitted?
was it loose?
was the wrong oring material used and they disolved?
4 of the frame bolts that go into the engine were loose. After tightening them down the leak slowed way down. It still leaks but very very little, a drop every few minutes. I think if I replace the o-rings again and with the bolts tight I should be ok? Thoughts?
2007 HONDA TRX250 RECON ATV (A51247)
2007 HONDA TRX250...
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2018 GENIE GTH636 TELESCOPIC FORKLIFT (A51246)
2018 GENIE GTH636...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A53472)
UNVERFERTH 330 8...
