I need my 1952 Ford 8N to start... please help!!
   / I need my 1952 Ford 8N to start... please help!! #11
possible? sure.. especially if headbolts and some juoker didn't retrofit studs.
cramped? yes.. but doable.
i would not be pulling the head till i pulled valve side cover and worked on them thru that. I have gotten N valves freed up using penetral thru the side covers.
exactly what i mentioned.
pull valve side covers... i bet for find the intakes for 1 & 2 stuck open.
I pulled the covers for 1 and 2. What should I be looking for? All looked good. I turned over the engine and all 4 valves moved. Basically what looked like up and a 1/4 turn. Will upload video when I get back to broadband.
Is that what I'd be looking for?
   / I need my 1952 Ford 8N to start... please help!! #13
Unfortunately if you verified they are all moving just as much as one another, then start taking that hood off.
   / I need my 1952 Ford 8N to start... please help!! #14
yup.. if you have cyls with -0- compression and the valves are all moving the same.. then that's bad.
like holed pistonshattered cyl liner..
deffinately start taking hood off...
   / I need my 1952 Ford 8N to start... please help!! #15
Or look on craigslist for one that is running. :thumbsup:
Buying one that is running might be cheaper in the long run.
   / I need my 1952 Ford 8N to start... please help!! #16
Depends on what is wrong really
Here are the vales from the cover plate angle...
   / I need my 1952 Ford 8N to start... please help!! #18
I have a 8n, and your motor should be turning over faster than that. I would bet it is either a broken ring or a whole in the piston.
Sent from my DROID RAZR HD using TractorByNet
   / I need my 1952 Ford 8N to start... please help!! #19
even a broken ring will make some compression. a snatched out liner or holed piston could put out near zero though
   / I need my 1952 Ford 8N to start... please help!! #20
Broken crank will allow 3and4 to turn over 1 and 2 won't. Does the fan turn while you try to start it?
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
2022 SIDUMP'R 48FT TRI AXLE SIDE DUMP TRAILER (A54607)
2022 SIDUMP'R 48FT...
2019 RBR Venturi 380 (A53473)
2019 RBR Venturi...
Super Star Smithco Bunker Rake (A50324)
Super Star Smithco...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
Quick Attach EZ Axe Skid Steer Tree Shear (A53473)
Quick Attach EZ...
