- Joined
- Aug 31, 2001
- Messages
- 66,061
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Possibly. I would have though with it kept low, it would lower the CoG, regardless of where it is suspended from. The FEL is suspended at a point higher than the CoG of the tractor, yet with it low to the ground, ot lowered it. And the higher the FEL is elevated, the higher the CoG
Just because its low to the ground doesn't mean its weight is supported low to the ground. The brush hog is supported behind the rear axle, further from the center of gravity. The FEL is supported between the axles, close to the center of gravity.
Try this (without the neighbors watching).
Stand on your right foot with a full oil can in your left hand and extend your left arm all the way out to your left side, keeping your right arm at your side. You can feel your body pulling to the left. Now bring that oil can in and hold it against your stomach. You stable right up, don't you? The oil can out to the side represents your brush hog. The oil can at your belly represents the FEL. No weight ever changed. Just the location of the weight.
