Ballast Water in rear tires = more stable??
   / Water in rear tires = more stable?? #32
Here's a very interesting study on tire inflation, singles, duals, triples and tracks. It mostly deals with traction and inflation, but one note towards the bottom referring to ballast reads:
Whole article.
http://www1.agric.gov.ab.ca/$department/deptdocs.nsf/all/eng8282/$file/Single,_Dual_and_Triple_Tires_and_Rubber_Belt_Tracks_in_Prairie_Conditions.pdf
I couldn't get that article to load as this is all I saw:Error 404
HTTP Web Server: Item Not Found Exception
   / Water in rear tires = more stable?? #34
You Southern Gentlemen have it good where you can fill your tires with water and get to work. Try that in Vermont where it gets to -30 below EVERY winter and that will not work. I have 'Rim-Guard' in mine(beet juice) and with the chains on in winter I have no problem. Steel or iron cast weights tend to collect dirt and salt between them and the rim they are bolted to reducing rim life. Also as they are balanced around the axle hub their positive effect on the tractors center of gravity is less (not zero just somewhat less) then the same weight of fluid sitting in the bottom of the tires. Set your rears wide and fill them with something right for your area. It might well save your life.
If you are worried about the little bitty difference between the Center of gravity with fluid vs cast. What do you do about the raised Center of gravity when that fuel tank is full vs empty? What do you do about a 150lb operator and a 250lb operator raising the Center of gravity ? What do you do about the effect of sloshing liquid ballast. The force will contribute to rollovers when a wheel is jolted by a bump.
   / Water in rear tires = more stable?? #36
What he's asking is are you just making this $%^&! up or do you have some links to some facts you can share?
buickand"dear"
Has his own personal ideas of how things should be performed EXCEPT in his own household where his wife is BOSS. She won't even let him buy a MFWD cab tractor to move snow!!!!!! That's the reason I altered his HANDLE.:D:dance1::D
   / Water in rear tires = more stable?? #37
No I'm not worried about the difference in the COG. The original poster was and both cast iron hub weights and fluid filled tires improve it. You can't do anything about where the fuel tank is or the operator in the seat so it is pointless to worry about them. There are good and bad points to liquid ballast that have pretty much all been brought out and examined up thread. I chose liquid plus spacers plus the widest tire position as I work on some very steep wooded ground. Other people have other work conditions and priorities so I'll let them make their own decisions after relating why I made mine.
   / Water in rear tires = more stable?? #38
buickand"dear"
Jim . Have you been texting mrs B&D again ?
   / Water in rear tires = more stable?? #39
Nope my crippled fingers aren't suitable for texting. You must be getting Oldtimers as you stated a little while back that she wouldn't let you buy a MFWD tractor to move snow. Remember you stated she insisted kitchen remodel,vacation & fur coat came 1st!!!!!!!!!:dance1::D:dance1:
   / Water in rear tires = more stable?? #40
He's full of it. It's actually 87 hours.
"All statistics on the internet are made up."
That's a direct quote from Abraham Lincoln, therefore it's true.
2009 L3 GENERATOR SET (A51222)
2009 L3 GENERATOR...
2020 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
2021 JCB 3TS 8T SKID LOADER (A51242)
2021 JCB 3TS 8T...
2015 BOBCAT E35 EXCAVATOR (A51242)
2015 BOBCAT E35...
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
John Deere 7200 Max Emerge II 16 Row Corn Planter (A52349)
John Deere 7200...
