Rear trailer brakes overheating
   / Rear trailer brakes overheating #31
Did you notice any difference in the magnets or magnet wire color? There are different magnets used in the various brake assemblies within a size 2x10, 2x12 etc. The rear axles may have a different magnet that is causing more braking than the fronts.
   / Rear trailer brakes overheating #32
Also possible for the primary and secondary shoes to be installed wrong. This can lead to self-tightening. The lining is located differently on the two shoes sometimes hard to tell which is which. I would compare with the front brakes to see if the shoes are installed the same way.
   / Rear trailer brakes overheating #33
Not sure if it's the same on trailers but on cars the shoe with more lining goes towards the rear
   / Rear trailer brakes overheating #34
Another question? when I slowly step on the brakes I always see the full output on the digital controller, if I set it to 7.0 then when I touch the brakes it says 7.0 is this correct? seems to me it would have to be this way as its hooked to the brake lite wire I think
My controller ('03 Silverado) slowly counts from 0.0 up to the setting I dial in depending on which trailer I am towing.
   / Rear trailer brakes overheating #35
Never trust used trailer wiring :D
A few years back we bought a nice used 5th wheel. I was all set up for towing with the truck, since I had been trailering my tractor now and then for years. The 5th wheel did ok, but I noted the rear brakes seemed to heat a bit, and on steep downhill runs, even the truck brakes warmed.
I was repacking bearings and checking brakes, and found the rear brakes worn. As I investifgated, I finally hooked the 5th wheel cable to the truck. Low voltage. Chased it all over the place(had my wife working brakes and controller in truck). I even brought my neighbors truck over to see if it was my controller.
I finally found someone had worked on the wiring, and basically miswired the front axle; it had been running on rear axle brakes only. I drew up the schematic as I traced wires
Fixed that, repacked bearings, new shoes on rear axle. It works great now.
I checked the front the other night they work fine and release fine, as mentioned here by someone I think the backs are dragging or not releasing these brakes were all redone by the guy I bought it from, all are fairly new and match up. I think I am going to try backing the rears off and towing it a bit for what ever reason they seem to be braking more.
thanks to all for the help !!If I ever figure this out I will post it
   / Rear trailer brakes overheating #37
Make sure the actuator lever moves smoothly/freely on its pin. Mine were all seized when I bought it as the PO never used the brakes. For me it meant no brake power, or little, but I suppose there's a possibility that it could engage and the spring not have enough gumption to overcome the rust to pull it free.
   / Rear trailer brakes overheating #38
With full brakes applied, have you confirmed 12V at all 4 brakes? I had ok voltage on the rear, very weak voltage on the front.
   / Rear trailer brakes overheating #39
I would look at the grounds from the brakes. Many will shortcut and ground to the frame. If you want to insure good grounding, a dedicated ground wire should be run from the brakes to the tow vehicle through the plug. You can find a protected area to attach a wire from the frame to the ground wire to complete the circuit for lights. On my tow vehicle, I run my ground wire from the plug all the way to the battery. This will help to eliminate poor connections. This is the recommendation of Dexter axle.
Next, I would check the amperage draw for each brake. Just because a magnet is getting voltage does not mean it is getting the proper amperage.
Dexter axle is a great resource for troubleshooting brake problems. Use the search function on their site.
Dexter Axle - Trailer Axles and Running Gear Components - Home
http://www.dexteraxle.com/i/u/6149609/f/Brake_Resources/Troubleshooting_Electric_Brakes.pdf
Thanks I do have a ground to the plug I believe I will run one to the battery.
Thanks for the links I will go through these to see what I can find out.
Shaver HD10 Hydraulic Post Driver (A51573)
Shaver HD10...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
2019 Chevrolet Tahoe SUV (A52377)
2019 Chevrolet...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
