TuffTorq K46 Repair Guide with Pictures
   / TuffTorq K46 Repair Guide with Pictures #781
How is it reacting with the lever? Easy to push with it in or out? Without oil it would push easily with rod in or out as the rod opens a bypass in the oil route so it can be pushed. 90% sure it works that way. Be sure to let us know if I am correct, don't remember that being asked before.
   / TuffTorq K46 Repair Guide with Pictures #782
Update! I took it all back apart. Took my time. And got it back together the right way this time. Everything seems ok. I put it back on the tractor and....nothing. Jacked it back up. Went through the bleeding process, and boom. There's she went. Climbed right up the hill.
So, now, I have a follow up question. They sent me 3 liters of the synthetic oil. How much was supposed to fit into the T40 tranny? I got 2.33 liters into the thing. Since the machine needed bled, is it possible that it needs more oil in there? If I have to take it off and put more in, I'd rather do that now then mow a bunch and regret it. Thanks!
And thanks to everyone who has helped me along the way! I have a running tractor again!!
   / TuffTorq K46 Repair Guide with Pictures #783
Yes, since it needed bleeding, the fluid would have replaced some air in the system. It will probably hold a bit more fluid. Their "top off" procedure states 2.2L if just draining/refilling through the cap. Since you added a tiny bit more but it also needed bleeding, you may still be within that "20-25mm reserve" they state.
If it were me, I would still take it off to check and top up to the upper reserve measurement just for safety.
https://www.tufftorqservices.com/En...INTERNAL RESERVOIR CHECKING & ADDING OIL.pdf
   / TuffTorq K46 Repair Guide with Pictures #784
I have a JD L120 with about 1200+ hours of mowing/spraying 5 acres of pasture on it. (Yes 1200+ hrs) I don't remember how long ago I bought it from HD. When they first came out maybe? I live in FLA so it gets used year round. A year + or so back, with the help of this site, I did the oil change in itransaxel, with great results. NOW it is moaning/groaning loosing power again. So I took a different path.. :)
I just bought a BAD BOY Elete CZT 60 inch 30hp zero turn. It was a new left over 2013 model so I got a good buy on it. Now my problem is what do I do with the pile of J.D. junk in my barn??
Maybe one rainy day I will do the oil change again but from a lot reading this post, I am thinking it needs the rebuild but for now I will use it to pull sprayer for the hour it will work untill it won't go I guess.
   / TuffTorq K46 Repair Guide with Pictures #785
   / TuffTorq K46 Repair Guide with Pictures #786
On the sunny side, if you paid 1200 for it, it cost you a dollar per hour to use. Not bad. I can mow my 1 acre yard in an hour.
It does sound like you need a rebuild.
   / TuffTorq K46 Repair Guide with Pictures #787
One more thing geezer, your's might have lasted the longest (without reading the whole thread again). 1200 hours is a long time for something like that.
   / TuffTorq K46 Repair Guide with Pictures #788
Hay Kyle it took me about an hour to mow mine with my JD also. Now it takes about 20min. :D I didn't read the whole post either :confused2: but it is the most hours I have seen on any forum. I wasn't very easy on it either. I haven't changed the oil in a cpl of years. It seeps oil from every orifice, so I figure I have a constant oil change & just add some now & then. :thumbsup: I have changed 2 of the 3 original blade spindles, & one of those twice. :confused3: & a couple of blade belts too. :cool:
   / TuffTorq K46 Repair Guide with Pictures #789
I was looking for some info on another transmission and found this link to new K46 transaxles for $219. I have bought from these people in the past and they are good to work with, have been around for a long time
TUFF TORQ K46 TRANSAXLE
   / TuffTorq K46 Repair Guide with Pictures #790
Informational Lot - Financing (A55315)
Informational Lot...
Hydraulic Hose Reel (A52377)
Hydraulic Hose...
2016 HAULMARK 24 ENCLOSED TRAILER (A55745)
2016 HAULMARK 24...
Ammco Brake Machine (A53424)
Ammco Brake...
2017 Ford F-150 Pickup Truck (A53422)
2017 Ford F-150...
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
