Buying Advice Kubota for NH woodlands
   / Kubota for NH woodlands #1
Garandman
Elite Member
Mount Sunapee NH / Dorchester, MA
Kubota L3200 HST
We are purchasing a camp with a little over 10 acres of land near Mt Sunapee, NH. There is a roughly 200 yard gravel drive, about a half acre of grass and flowers behind the house, and about 150 yards of old stone wall on two sides of the cleared area, although brush and saplings have started encroaching and will have to be cleared to see the stone wall again. There is a mountain brook that runs through the front of the property and the land near it is wet in the spring. There is a good-sized garage that should accommodate anything we might use.
There are a few trails on the property and we'd like to start maintaining the forest, so we might have to be doing some skidding if we choose to drag a tree-length log out to a staging area, otherwise we would cut the wood in place to cord length or smaller and take it out in the bucket. The property slopes uphill from the house but I'm not sure how narrow any trails might be. There are a lot of trees: here shown the house, garage, and our new neighbors - the trees.
This is a second home, mostly for skiing and winter sports, and we plan to hire someone local to plow the driveway after storms, since we may not be there. But we will have to clean up after storms, in particular the snowbanks at the end of the drive as it's hard to see out. We have a walk-behind snow thrower (Ariens 926 Pro) to clean up around the house.
I've spoken to the dealer about a B2920SU and an L3200, both with FEL and backhoe. The suggestion is that we will need the backhoe for stumps and stone wall maintenance, will the FEL will be handy for snow cleanup, moving dirt, stumps, firewood etc. A brush cutter is probably in the works but I am going to buy a heavy-duty string trimmer first to go exploring, as there are some sloping areas that I won't be able to clear anyway.
The dealer suggests that the L3200, being heavier and with a higher capacity implements, is a better tractor for woods clearing than the B series. But when I visited the John Deere dealer he had another take. He suggested that after a year or two of cleanup, a machine of that size would be too big and I would be better served by getting a smaller tractor and working it harder.
I can see both sides of that coin here: some people who've bought "too big" and others who've bought "too small." Most of my friends with tractors have B series of 20-something horsepower and are content, so the idea that I might be going too big is at the back of my mind.
Am I missing anything?
   / Kubota for NH woodlands #2
I'm with the dealer that suggests the L. Not that much bigger than a B, but the extra weight lets you apply the power to the ground.
BTW, beautiful camp!
   / Kubota for NH woodlands #3
I had a light-frame Kubota B3300SU tractor-loader. Now I have a heavy frame L3560 tractor loader, only slightly larger than the B3300SU.
The heavier tractor is much more stable/safe performing the tasks you have outlined on sloped ground.
Especially if you do not have considerable tractor operating experience, buy the heavier L3200.
   / Kubota for NH woodlands #4
look @ MX 5(?)00 for the job. your site is awesome. can't go wrong w/mx for power & agility in your applic imho btw the trees are the best of neighbors...
   / Kubota for NH woodlands #6
Consider getting the biggest bucket available... my old B8200 had a 4' bucket, my newer L3130 has a big 6' bucket, and the difference in the amount of firewood I can load in it is maybe twice as much, or even more... it ain't the weight, it's the volume.
   / Kubota for NH woodlands #7
Looks like I'll go ahead with an L3200, FEL, backhoe, quick release bucket, possibly brush cutter.
SSQA (Skid Steer Quick Attach) bucket is a good idea.
Pin on quick attach bucket is not a good idea. I had a pin on quick attach bucket on my B3300SU. In the woods, brush flipped off a lynch pin, a FEL pin worked out and the FEL support was bent; an expensive repair.
It's optional but the standard skid steer system, seems a no-brainer. Don't recall the bucket size but I want a big 'un for snow.
What is a "3-Point Stabilizer Kit?" Is that just a screw on stabilizer set?
Do I want cruise control? I'm working in a 700 foot box. $205.
   / Kubota for NH woodlands #10
Not sure about the stabilizer kit but I find cruise control handy even when working in a smaller area . It is not needed but very nice to have .If you ever decide to use a snow blower it would be great to have . Good choice on the L series .
   / Kubota for NH woodlands #11
I think the 3 point stabilizer kit is a telescoping stabilizer setup. Take a look at Stabilworks for an idea of what I mean. My Grand L came with a similar OEM system, standard. I found the turnbuckles on our B Series tractors to be so time consuming I got a set of the Stabilworks aftermarket stabilizers for each of the B's. Makes implement change much, much faster. It will also allow you to push with 3pt implements (within reason) without damaging the turnbuckles.
If you plan on doing lots of box blade, rear blade or rear fork work, consider getting Top-N-Tilt. It transformed my L series into a much more productive machine. It also alows me to use a brush hog to knock down heavy undergrowth in uneven terrain and cramped quarters with much more "surgical" results.
Since this will be for your home away from home, anything you can do to reduce the time it takes you to do a job means you can get more done or go do something else with the limited time you have there.
What about:
Rear Remote Hydraulic Valves
Mounting Base with Valve Kits
  • None
  • 1ST POSITION HYDRAULIC VALVE & LEVER KIT
  • PLUS 2ND POSITION VALVE KIT (CHOICE OF VALVE FOR 2ND POSITION)
  • PLUS 3RD POSITION VALVE KIT (CHOICE OF VALVES FOR 2ND & 3RD POSITION)
   / Kubota for NH woodlands #13
What about:
•None
•1ST POSITION HYDRAULIC VALVE & LEVER KIT
•PLUS 2ND POSITION VALVE KIT (CHOICE OF VALVE FOR 2ND POSITION)
•PLUS 3RD POSITION VALVE KIT (CHOICE OF VALVES FOR 2ND & 3RD POSITION)
You'll need the 1st & 2nd kit for Top-N-Tilt.
Make sure you're sitting down when you price them out.
If you're handy, you can cobble your own set together and save some $ at the expense of a very clean & compact installation.
   / Kubota for NH woodlands #14
You want the 3 pt stabilizer kit. I think it added $150 to the price of my L3200, but it is very much worth it as it makes changing implements much easier vs. the standard turnbuckle style stabilizers.
   / Kubota for NH woodlands #15
Bigger is better, in my humble opinion... I bought an L3800 here in Tenn. After a year and a half, I still love the tractor, but I wish I went the next size up (possible to an M class).
   / Kubota for NH woodlands #16
Welcome to TBN and central NH.
I'm one who wishes he had bought bigger. The box blade or York rake would be a big plus.
Of course now that I am leaning towards Kubota, the Kioti and Mahindra fans are bbecoming more vocal.....
So after looking around our NH property I'm starting to wonder what I would actually do with a compact tractor.
  • Because we won't be there most of the time we will have to get the driveway plowed anyway.
  • Driveway hasn't been maintained so it's going to need three dump loads of gravel mix: spreading and compacting 60 tons doesn't seem practical.
  • If I get ag tires they will tear up the grass, but turf tires won't cut it in the woods, so I'd need a mower anyway.
  • We could use a perimeter drain and some grading in the back yard but most of the rocks are too big for anything but an excavator of some sort. Just measured up one and it's about a cubic yard - roughly one ton. Buried.
  • I do want to make some trails, but so far the tool I've used the most is the Stihl brush cutter with steel blade, followed by a machete.
It looks to me like an ATV with a dump body might be more practical, or a much smaller tractor with a belly mower. Am I missing something?
   / Kubota for NH woodlands #19
   / Kubota for NH woodlands #20
Sounds like you are in a similar situation as myself (i.e. lots of woods, need a machine), except I don't have the snow to deal with. A small tractor with belly mower will be fine unless you are contemplating heavy tree clearing work. I have an ATV, but I seriously doubt it will help me grade the road. There are attachments you can buy but they are expensive and I have doubts to how effective a 500-600 lb machine can be.
2025 40ft 10-Door Shipping Container (A59228)
2025 40ft 10-Door...
2012 International Prostar (A56438)
2012 International...
2016 John Deere 4044R 42HP 4WD Utility Tractor (A59228)
2016 John Deere...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2021 SANY SY265C LC LONG REACH EXCAVATOR (A59823)
2021 SANY SY265C...
