120v MIG 3/8" coupon test results
Status
Not open for further replies.
   / 120v MIG 3/8" coupon test results #1
ericher69
Ontario Canada
2008 Kubota b2920
Fireflaker
Any update?
Sent from my iPhone 5s 64Gb using TractorByNet
   / 120v MIG 3/8" coupon test results #2
He warned people a number of times that if they didn't stop arguing, then he would stop posting his results. I would expect that since the arguing continued and the thread was closed, he has kept his word.
Really unfortunate that many people end up losing because of the actions of a few. I was also very interested in hearing the results of the testing and any recommendations that he was able to make on how to get the best out of my 120v machine. As well, he was putting a lot of time and effort into the testing which should not have to go to waste.
   / 120v MIG 3/8" coupon test results #3
ditto
   / 120v MIG 3/8" coupon test results #4
If my machine shutdown after one inch of weld I'da gave it up too. Need some fellas better equipped, Miller, for example? :D That Century shield was using wasn't shutting down (welder not WeldOR).
Maybe an Everlast 140E can finish up.
   / 120v MIG 3/8" coupon test results #5
Did this quick today at work
3/8 with 45* bevel
Tacked and welded two passes then ground the root and welded one pass to bring it flush
Root bent, can see crack developing in area of start, rest of weld looks good
No cracks at all in welded area but can see base metal actually starting to rip approx 1/4" above weld
   / 120v MIG 3/8" coupon test results #6
Thanks for doing the test, firemanmike. :thumbsup:
   / 120v MIG 3/8" coupon test results #7
I just got tired if all the bickering and nonsense on here so I just decided to stay late at the shop and bang a coupon out quick because I don't have a 110 mig at home. The machine I used was a millermatic 140 with .030 wire and c25 gas
   / 120v MIG 3/8" coupon test results #8
Settings? I assume you had it cranked all the way up? Thank you for sharing. Great pics and to the point!!! :thumbsup:
   / 120v MIG 3/8" coupon test results #9
Thanks again Fireman. Experienced welders have been "imagining" the limits of 120v MIGs for so long, it's time! The opposition to this "project" has been either amazing, humorous, or pitiful.
Everybody should know that a 120v MIG pushin' it at 3/8" but also they should know it "can do it" with weld prep and knowhow, in a pinch. It's pretty much the same methods that any experienced welder knows when welding thick stuff just that nobody will show 120v MIG owners how to do it. It depends on the weldment size, and the application too.
The notion that 120v MIG can only weld 12ga, is out the window. Or ought to be, I guess we'll see how long that takes! :laughing:
   / 120v MIG 3/8" coupon test results #10
Good stuff. Thanks for posting.
Status
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
2016 Ford Escape SUV (A50324)
2016 Ford Escape...
2011 ORTEQ ENERGY SERVICES 40 MANIFOLD TRAILER (A50854)
2011 ORTEQ ENERGY...
10x16.5 Tire Assembly (A52128)
10x16.5 Tire...
2015 FREIGHTLINER CASCADIA DAY CAB (A51219)
2015 FREIGHTLINER...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
