Question about using a landscape rake
   / Question about using a landscape rake #1
lzicc
Pittsburgh, Pa
Kubota B2650
I have a KK landscape rake and I noticed that you can turn 180 degrees. What would be the purpose of doing that?
   / Question about using a landscape rake #2
I use mine turned around for smoothing. This way you don't collect much material. ;)
   / Question about using a landscape rake #3
There's a nice informative video on YouTube by everythingattatchments about all the uses for a landscape rake.
I like that. I wonder if that would work well on a limestone driveway. When I use it on the driveway the regular way, it picks up the too many stones.
I use mine in turned around for smoothing. This way you don't collect much material. ;)
   / Question about using a landscape rake #5
Going forward with rake in reverse you can shallowly cover seed beds, especially wildlife food plots.
Sometimes a LR works better pushing yard debris into piles when reversed and the tractor is operating in reverse.
   / Question about using a landscape rake #6
I run in reverse when I do not wish to drive over piles. Especially piles that could puncture tires, namely old boards complete with nails poking out.
   / Question about using a landscape rake #7
Yes it will indeed,that's how i smooth mine after boxblading the holes out and then using the rake to crown.
   / Question about using a landscape rake #8
That's how we smooth and level gravel with our ROBB too, run forward with the blade facing backwards, it's like using a spatula to smooth out frosting on a cake.
In fact, I'm looking around on EBay for a new shorter top link to make it tilt forward even more and allow it to smooth more and transport even less stone from one place to another.
   / Question about using a landscape rake #9
Wait a minute. I don't know abut this and from the comments I'd say I'm the last to know.
Can you explain more how this works for dirt of gravel a little larger than you have? Sounds like a great idea.
   / Question about using a landscape rake #10
SIXDOGS: I thought you knew EVERYTHING related to tractors and women.
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
2013 Ford C-Max Energi Hybrid PHEV Hatchback (A59231)
2013 Ford C-Max...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
2020 CATERPILLAR 299D3 SKID STEER (A60429)
2020 CATERPILLAR...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
iDrive TDS-2010H...
