The only thing in this thread that has me thinking is the statement about using a bigger breaker to supply the welder with more amps, and would it allow more output at the business end of the welder. I dont know, so am asking if its possible.
With that said, I was trying to tig some 3/8 aluminum with my 220v 250 amp machine the other day. I have a 60amp fuse (yep, I said fuse), in my panel, actually 2 big fuses, about 1in dia and 6inches long, at $17 each. While trying to tig the aluminum, with machine set on 250amps, I blew one of the fuses. Installed another fuse and blew it too. Pretty sure the machine is supposed to be fused at 60amp and darn sure the machine was at max capacity. Recommended amp for 3/8 aluminum tig weld is 230-260 amps, so I was at the limits for my machine, kind of like the 120migs on 3/8 steel. Not sure I would want to use a bigger fuse to power the welder, in fact, I plan on a whole new breaker panel installation next wkend. Still, I wonder if using a bigger breaker than 60amp would or would not damage my machine, and I plan on dragging the welder out from the wall and checking the panel on the back to see if the machine is indeed supposed to be wired to a 60amp breaker or fuse, or if maybe it might suppose to have a even bigger power supply. Machine is a idealarc 250/250 stick tig with high fre start.
I should probably also note that I am a beginner tig welder and just happen to have a aluminum spindle housing off a lawn mower that was really beyond repair, and I just wanted to know if I could weld it using tig, just for practice. I realize my welder, even tho it is a 220v machine would be pushing the limits for tig welding 3/8 aluminum and I aint beyond paying someone with the right equipment to weld a job I am not equipped to do myself. I think thats something some of the guys that want to keep pushing the limits of their 110v migs should take into consideration.
