Question about using a landscape rake
   / Question about using a landscape rake #1
lzicc
Pittsburgh, Pa
Kubota B2650
I have a KK landscape rake and I noticed that you can turn 180 degrees. What would be the purpose of doing that?
   / Question about using a landscape rake #2
I use mine turned around for smoothing. This way you don't collect much material. ;)
   / Question about using a landscape rake #3
There's a nice informative video on YouTube by everythingattatchments about all the uses for a landscape rake.
I like that. I wonder if that would work well on a limestone driveway. When I use it on the driveway the regular way, it picks up the too many stones.
I use mine in turned around for smoothing. This way you don't collect much material. ;)
   / Question about using a landscape rake #5
Going forward with rake in reverse you can shallowly cover seed beds, especially wildlife food plots.
Sometimes a LR works better pushing yard debris into piles when reversed and the tractor is operating in reverse.
   / Question about using a landscape rake #6
I run in reverse when I do not wish to drive over piles. Especially piles that could puncture tires, namely old boards complete with nails poking out.
   / Question about using a landscape rake #7
Yes it will indeed,that's how i smooth mine after boxblading the holes out and then using the rake to crown.
   / Question about using a landscape rake #8
That's how we smooth and level gravel with our ROBB too, run forward with the blade facing backwards, it's like using a spatula to smooth out frosting on a cake.
In fact, I'm looking around on EBay for a new shorter top link to make it tilt forward even more and allow it to smooth more and transport even less stone from one place to another.
   / Question about using a landscape rake #9
Wait a minute. I don't know abut this and from the comments I'd say I'm the last to know.
Can you explain more how this works for dirt of gravel a little larger than you have? Sounds like a great idea.
   / Question about using a landscape rake #10
SIXDOGS: I thought you knew EVERYTHING related to tractors and women.
IRTPL LIFT (A58214)
IRTPL LIFT (A58214)
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
Adams Tilt Trailer (A56438)
Adams Tilt Trailer...
John Deere 7410 (A53317)
John Deere 7410...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
