120V MIG 3/8" coupon test results
Status
Not open for further replies.
   / 120V MIG 3/8" coupon test results #21
And its not MIG if its flux core. Its not potato/potato, tomato/tomato. There's a huge difference. So please get the nomenclature correct. ;)
Again, I quote from this link from Lincoln Electric...
GMAW vs FCAW-S Process
Lincoln Electric said:
General Usage Rules
MIG
As a rule of thumb, it is recommended to use a compact 115 volt input (or 230 volt) MIG wire feeder welder indoors on clean new steel that is 24 to 12 gauge thick. 12 gauge is a little less than 1/8" thick. 24 gauge is less than 1/16" thick. The smallest wire (.025") will make it the easiest to weld the thinnest (24 gauge) material. The .030" diameter wire will weld a little faster deposition rate. If you need to weld 1/8" to 1/4" thick material with MIG, you will need the higher capacity compact machine which will require 230 volt input. The higher amperage range of this machine can better handle your welding needs in a single pass and you may not have to waste time with second or third passes. The 230 volt machine could also run .035" diameter wire. To MIG weld material more than 1/4" thick, you need a higher capacity truly industrial machine. If most of your welding will be performed indoors on clean material that is less than 1/8" thick, a MIG machine that operates on 115 volts is probably your best bet for economic reasons in that a 230 volt input machine will be more expensive.
Flux-Cored
The flux-cored process is only recommended on materials as thin as 20 gauge, a bit thicker than the 24 gauge we said for MIG. In general, this process is best for welding thicker materials with a single pass, especially if you need to weld outdoors such as to repair a tractor out in the field. A 115 volt flux-cored machine using an electrode such as .035" Innershield NR-211-MP will generally allow you to weld steel up to 1/4" thick. Note that this is more than double the thickness maximum of 12 gauge with MIG on 115 volts. With the proper electrode on a proper machine, such as .045" Innershield NR-211MP, and a 230 volt input machine, you can weld steel up to 1/2" thick. Note that Innershieldョ NR-211-MP requires that the machine be setup for DC negative polarity.
Now there's no harm in trying it for yourself, but telling people its O.K. for everyday use items is kind of irresponsible.
   / 120V MIG 3/8" coupon test results #22
I'm
What about helping members, who occasionally weld thicker than the recommended ,,,, how to do it? Also the link is from Lincoln, whereas Hobart & Miller Machines are capable of welding up to 1/4" steel, no need to use Lincoln's limitations. Besides it's a little too late for that we're way past 12ga with other 120v machines.
Understood some members find it upsetting when 120v MIG owners get "too big for their britches". I for one do not believe that forum members are welding much in excess of 1/4", that is, if they are doing any projects at all.
When posts of "what you cannot do" far exceed "what you CAN do", its reasonable to conclude that not much actual welding is occurring here. And will probably stay that way as long as the 240v members have a need to assert themselves over the 120v members. There could be more forum activity when this "need" passes.
   / 120V MIG 3/8" coupon test results #23
I don't get it. First this is supposed to be a hobby/maintenance forum and the "pro's" don't know what they're talking about and their experience doesn't count for anything. Then the same pro's are expected to pass a bend test, they thought was possibly doable with a lot work, just to prove it could be done because no one else has been able to do it. The people campaigning it can be done can't or don't want to do it for what ever reason or excuse works for them. Pictures are posted of someone almost doing it with the ends cut off but still enough of a flaw to constitute a fail. Text from one of the largest and most respected names in welding clearly outlines the limitations of 110 volt wire feed welders (which coincidentally agree's with what the "pro's" have been saying all along) but they don't know what they're talking about either. Another highly respected name in welding say's up to 1/4" is maximum but that's still not to be believed.
Where's Linus when you really need him:confused: If he can explain the meaning of Christmas to Charlie Brown, he'd be the best bet to explain how a 110 welder can pass a 3/8" bend test. It's like Lucy pulling the football away from good ol' Charlie Brown at the last second. Almost but not quite. All I can say is Good Grief!:duh:
   / 120V MIG 3/8" coupon test results #24
I absolutely loved how this thread started out... with some flat out good humor. Let's stay positive and learn something. Too bad some of us have to wade through puddles of testosterone to find gems about welding. Some of us have what we have and appreciate 'MacGyvering' things. No, I'm not talking about a trailer that is going to break and kill someone... but a trick that just might save oneself in a pinch.
   / 120V MIG 3/8" coupon test results #25
I will stand by what I have said earlier, I think it is irresponsible to suggest to every Tom, Dick and Harry that goes out and buys a 120v mig machine, that it is ok for them to weld 3/8 metal with it
This has been a common theme throughout all these threads. It is probably a major reason pleas for a pro to attempt this have gained zero traction. Professionals understand that demonstrating that something can be done, does not make it acceptable. I am a professional (not a professional welder) and I know tricks for getting things done in my field that will pass 90% of the time. I also have a good feel for, and avoid the pitfalls that result in the 10% that will fail and don't apply tricks in those situations. As a professional I would never go public with suggesting one of these tricks is acceptable.
   / 120V MIG 3/8" coupon test results #26
Please tell me you aren't a surgeon... :D
hopefully not but having said that and having seen many surgeries I can honestly say that plenty of MacGyvering goes on in the operation room.
See the differences IMHO is professionals with education, knowledge, experience that know how to troubleshoot issues to get the job done safely giving favorable outcomes. I am applying these observations to Weldors and surgeons.
Sent from my iPhone 5s 64Gb using TractorByNet
   / 120V MIG 3/8" coupon test results #28
What's really strange is how you continue to show up and say the same thing over and over and over. You have made your point but for some reason that is not good enough and even after it has been proven possible you still seem hung up on trash talking.
We test the limits of machines all the time. I tried to lift a pallet of treated lumber with my tractor last weekend and it was more than the tractor was rated for but with some creativity I was still able to get it off my trailer using the tractor. I suspect most of us have operated equipment beyond it's rated capacity yet nobody comes in telling us how unsafe that is and how we are going to kill somebody trying to lift more than the tractor is rated to lift. But for some reason you feel the need to come here and tell us all how wrong we are over and over. If you want to contribute then please contribute. But if you are simply here to start a fight and say the same things over and over simple move along to anther thread where you can contribute and not bring the negativity that you constantly do on these 120v welder threads.
Please stop whining about how nobody respects a professional welder. It's absolutely not true and quite frankly you seem to get you feelings hurt way too easy if someone doesn't follow your advice just like SA did.
And you can stop pretending that a 120v welder can't pass a 3/8 bend test as it has been proven to be possible with a tremendous amount of preheating and a skilled operator. I suspect you will still run around telling everyone how it's not true because you feel threatened by 120v welders and will do anything possible to run down their capability and usefullness but as I said earlier a simple Google search will prove it to be true.
   / 120V MIG 3/8" coupon test results #29
Road, the locked threads can still be read, you can go back and reread all of my old posts and I said many times I thought it might could be done. I didnt just come on here after you posted a supposed passed bend test and change what I have said in the past. I will stand by what I have said earlier, I think it is irresponsible to suggest to every Tom, Dick and Harry that goes out and buys a 120v mig machine, that it is ok for them to weld 3/8 metal with it, even if someone somewhere did manage to pass a bend test with. If indeed the bend test was passed, the amount of prep time involved is probably over the patience/skill/knowledge level of most would be weldors and they are bound to take short cuts with the task. I equally sure that there are plenty of new 120 mig owners reading this and other forums, and most are just itching to put their new welders to work. I dont think they should be misled into believing their 120v machines can safely build whatever their project might be based on somebodies insistance that 120v mig machines can safely weld thick metal. Further, the bend test results you have posted where not mig welded they where fcaw and there is a difference. Just because a welding machine runs wire doesnt mean its mig welded. I also wouldnt reccommend FCAW with a 120v machine on 3/8 steel.
The strange part is nobody is recommending that people do any critical welds on heavy material with 120v welders. Nobody is trying to mislead other folks into believing their 120v welder is good to use on 3/8 material. Nobody is telling people to do anything unsafe. Heck all that we are dealing with is practice pieces. We talking bout practice, practice??, we talking about practice.
The bottom line is you can continue to show up and lecture us on how this is unsafe and how this is not something that should be done on a critical weld, 120v welders are not suited to weld 3/8 material, etc, etc.. or you can realize that nobody is even suggesting any of that and you are basically just arguing to argue as nobody is disagreeing with what you are saying. Hopefully once you realize that you will be able to contribute.
   / 120V MIG 3/8" coupon test results #30
Above you mention that 120v welders are not rated for 3/8" plate. Not true. SMAW will run on 120v CC machines well and heavier than 3/8" will be fine with proper technique. That is a tip I suggested many pages ago but it was not what some were looking for but that is the tip I can offer.
120v CV machines on plate can hold that has already been noted. Preheat, flux cored, and joint prep are ways to improve the chance of a strong weld on materials heavier than 3/16".
What else could you possibly be looking for?? Let me know and I will try and answer.
Status
UNVERFERTH 210 (A53084)
UNVERFERTH 210...
2015 FORD F250 EXT CAB SUPER DUTY (A53843)
2015 FORD F250 EXT...
2009 PETERBILT 365 (A53843)
2009 PETERBILT 365...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
2014 Jacobsen AR3 Commercial Mower (A53421)
2014 Jacobsen AR3...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
