Straight or swirls?
   / Straight or swirls? #11
Some people go in circles when MIG welding.
My only reply to that is "WHY?" Moving in and out of the puddle only increases the chances of puddle cooling and slag forming under the next swirl.
As FarmDad said, a back and forth stepping motion might be seen as a circular motion.
The only reason to step out of the puddle when welding is to allow the puddle to cool a bit so you can fill up a gap like when running an uphill bead.
Stepping motion is also used when running a hot pass but the motion is a bit more than just stepping, it also has a shortening and lengthening arc motion. The short arc motion allows the rod to dig into the base metal gouging out any impurities and then the long arc allows them to float to the surface. It is no way considered a circular motion.
You may not see any effects on your farm welds by using circular motion other than ugly welds but if xrayed you would surely see lots of defects.
Stick with a side to side zig-zag or U shaped motion or just drag it. The faster the motion, the closer together the ripples will be and thus smoother the weld.
   / Straight or swirls? #12
Sometimes I do circles (more like lowercase cursive e's) when mig welding.
Sometimes I go straight, sometimes weave, sometimes others. Just depends. Material thickness, joint type, position, all come into play.
Back to the whole circle thing, there is a handfull of times it is nice. When trying to fill a gap. Im not talking a 1/8" gap in 1/4" steel. But something closer to material thickness. Doing the circle thing, when going forward you basically go up one edge of the metal, back down the other, and lap over the weld where the pieces are together. Then repeat. It gives the welded area a change to actually cool, as well as give a little more material out front for the next pass. IMO, it allows you to weld hotter vs just doing a weave.
   / Straight or swirls? #13
Like almost everything in life, it depends. I use them all from time to time. Zigzag, circle, straight, push, pull, it just depends if the situation needs it.
As for your welds being good/bad from time to time and you think you are doing the exact same thing, how about your surface preparation? Might a good weld be with new material that is clean and a "poo" weld be old painted/rusty iron that just needs to be hit with a sander or grinder?
   / Straight or swirls? #14
Yes, a lot of people use little cursive "e's" in welding...MIG mainly, but in general I think you are talking simply about weaving, not swirling...and running "straight" is called running a "Stringer" bead. The " E" patter causes the arc to "bite in" in front of the puddle. and fuses the root, especially when pushing MIG. It doesn't cause issues if done correctly and not overexaggerated.
From the terminology that you are using (somewhat incorrectly) I can tell that you could really benefit from some self education on welding. There are numerous online free resources, including weldingtipsandtricks.com and other places that not only show you how to weld, but also do a fair job of explaining correct terminology. With all the free information out there, there's really not much left to the imagination about welding. FWIW "Coil fed" is wire fed. Or wire feed.
   / Straight or swirls? #15
Welding tips and tricks explains it very well and has a video. The cursive "e's" he's talking about are basically little circles at the front of the puddle.
You can say that two times!
Thanks for the inputs - I never think of youtube as a resource, but that is a terrific idea. Must be the "over 50" thing...
   / Straight or swirls? #17
Youtube is the number one search engine in the world! As a marketer, i have to remind myself of this often, so you are not alone!
   / Straight or swirls? #19
   / Straight or swirls? #20
You can also look at Kevin Carons vids. on You-Tube a lot of great info also....
2022 TAKEUCHI TL12R2 SKID STEER (A51246)
2022 TAKEUCHI...
UNUSED CHERY INDUSTRIAL SINGLE GARAGE METAL SHED (A51248)
UNUSED CHERY...
TAKEUCHI TL12V-2 SKID STEER (A51246)
TAKEUCHI TL12V-2...
Caterpillar 259D (A50123)
Caterpillar 259D...
2022 Big Tex 22GN-35BK+5MR 40ft T/A Gooseneck Equipment Trailer (A51692)
2022 Big Tex...
434669 (A48836)
434669 (A48836)
