Straight or swirls?
   / Straight or swirls? #1
Jay4200
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
I've owned welders and done DIY welding for years for the occasional project, but my welding hasn't really improved a whole ton. I've never had anyone show me what too fast or too slow or too cold or too hot looks like, so I'm having a tough time diagnosing what I'm doing wrong (or right). Sometimes my welds look absolutely great - with the whole stack of dimes thing, but other times they look like poo - holes and blobs and splatter...and I swear I'm doing the exact same thing with the same setup all the time. I'm trying to whittle down the variables...so bear with me if these are stupid questions.
When making a weld with either a coil fed (I use flux-core) or a stick, and ignoring any kind of fancy applications, are you generally supposed to run straight up the weld or weave the stick/gun back n' forth or around in little circles as you go?
Also, when running a stick weld, do you kinda press the rod into the metal as you go (or drag it against the surface) and let the arc do its thing for inherent distance, or do you actively try to hold the stick some fraction of an inch away from the weld?
   / Straight or swirls? #2
Yes. That is either way.
Look for welding videos on youtube from someone called "weldingtipsandtricks" He has the best welding videos on the internet.
And he shows many ways to move the gun and explains why.
Some you can/should drag the flux coating on the workpiece, others you hold them just above the puddle.
   / Straight or swirls? #4
I also got some good DVDs from a place called Wall Mountain.
I got the two stick welding DVDs, and they are great. I imagine the MIG welding ones are just as good.
   / Straight or swirls? #5
I cant think of any type of welding that uses swirls. A back and forth stepping motion or side to side zig-zag or U shaped motion stepping up a bit each U is about the only motion I can think of that wont trap slag or result in an un-uniform weld.
   / Straight or swirls? #6
Well after posting I did think of one swirl motion but it is used with acetylene welding, not arc welding.
   / Straight or swirls? #7
   / Straight or swirls? #8
I've seen a few guys use a small circular motion while using 6010/6011 when welding flat/horizontal, if that's what the OP means as "swirl".
My welding teacher in high school used the circular method. Other instructors and most welders I've been around, used the side to side technique in that position.
   / Straight or swirls? #10
Was the metal all the same? I would think splatter and such is caused by contamination. Oil, paint, dirt all cause havoc on welds. Might not be just technique.
   / Straight or swirls? #11
Some people go in circles when MIG welding.
My only reply to that is "WHY?" Moving in and out of the puddle only increases the chances of puddle cooling and slag forming under the next swirl.
As FarmDad said, a back and forth stepping motion might be seen as a circular motion.
The only reason to step out of the puddle when welding is to allow the puddle to cool a bit so you can fill up a gap like when running an uphill bead.
Stepping motion is also used when running a hot pass but the motion is a bit more than just stepping, it also has a shortening and lengthening arc motion. The short arc motion allows the rod to dig into the base metal gouging out any impurities and then the long arc allows them to float to the surface. It is no way considered a circular motion.
You may not see any effects on your farm welds by using circular motion other than ugly welds but if xrayed you would surely see lots of defects.
Stick with a side to side zig-zag or U shaped motion or just drag it. The faster the motion, the closer together the ripples will be and thus smoother the weld.
   / Straight or swirls? #12
Sometimes I do circles (more like lowercase cursive e's) when mig welding.
Sometimes I go straight, sometimes weave, sometimes others. Just depends. Material thickness, joint type, position, all come into play.
Back to the whole circle thing, there is a handfull of times it is nice. When trying to fill a gap. Im not talking a 1/8" gap in 1/4" steel. But something closer to material thickness. Doing the circle thing, when going forward you basically go up one edge of the metal, back down the other, and lap over the weld where the pieces are together. Then repeat. It gives the welded area a change to actually cool, as well as give a little more material out front for the next pass. IMO, it allows you to weld hotter vs just doing a weave.
   / Straight or swirls? #13
Like almost everything in life, it depends. I use them all from time to time. Zigzag, circle, straight, push, pull, it just depends if the situation needs it.
As for your welds being good/bad from time to time and you think you are doing the exact same thing, how about your surface preparation? Might a good weld be with new material that is clean and a "poo" weld be old painted/rusty iron that just needs to be hit with a sander or grinder?
   / Straight or swirls? #14
Yes, a lot of people use little cursive "e's" in welding...MIG mainly, but in general I think you are talking simply about weaving, not swirling...and running "straight" is called running a "Stringer" bead. The " E" patter causes the arc to "bite in" in front of the puddle. and fuses the root, especially when pushing MIG. It doesn't cause issues if done correctly and not overexaggerated.
From the terminology that you are using (somewhat incorrectly) I can tell that you could really benefit from some self education on welding. There are numerous online free resources, including weldingtipsandtricks.com and other places that not only show you how to weld, but also do a fair job of explaining correct terminology. With all the free information out there, there's really not much left to the imagination about welding. FWIW "Coil fed" is wire fed. Or wire feed.
   / Straight or swirls? #15
Welding tips and tricks explains it very well and has a video. The cursive "e's" he's talking about are basically little circles at the front of the puddle.
You can say that two times!
Thanks for the inputs - I never think of youtube as a resource, but that is a terrific idea. Must be the "over 50" thing...
   / Straight or swirls? #17
Youtube is the number one search engine in the world! As a marketer, i have to remind myself of this often, so you are not alone!
   / Straight or swirls? #19
   / Straight or swirls? #20
You can also look at Kevin Carons vids. on You-Tube a lot of great info also....
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
2012 DIAMOND T TRAILER TRAILER (A58214)
2012 DIAMOND T...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
2014 INTERNATIONAL PROSTAR+ (A58214)
2014 INTERNATIONAL...
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
29in forks and frame (A59228)
29in forks and...
