Electricians: Range wiring and breaker sizing code
   / Electricians: Range wiring and breaker sizing code #71
called illegal baiting;)
   / Electricians: Range wiring and breaker sizing code #72
You're kinda saying the same thing I am except for the highlighted part and maybe you missed where I said that "And that HIDDEN wiring for large fixed appliances with a receptacle/cord like in this case includes the receptacle.".
Lemme ask you this: you have a dedicated circuit for your refrigerator. Say your refrigerator max amperage is 8.5a. So you have an 8.5a breaker on that?
- Jay
Can't say I read what you wrote prior to posting.:confused3: Can't say I've ever seen a 8.5 amp breaker either. :confused2: 15 amp may be smallest for residential, IIRC? Don't quote me, I don't profess to have extensive knowledge of codes, more just a general knowledge of how things work; like breaker protecting the circuit wiring, etc. Basically just enuf' to be dangerous.:shocked:
Should I get r4's or AGS on my next tractor:)
   / Electricians: Range wiring and breaker sizing code #74
Neither
Treads!
   / Electricians: Range wiring and breaker sizing code #75
That'd be just what FTG-05 needs to bushhog his slopes!!
- Jay
   / Electricians: Range wiring and breaker sizing code #76
But what is the best weight and brand of oil to use in the tread drives? Synthetic or dino?
:rolleyes:
- Jay
   / Electricians: Range wiring and breaker sizing code #77
Hopefully some of you electricians that are well versed in code and all can help me out.
In the midst of selling my home and under contract. Home inspection was done, then I get the request for remedy sheet.
One of the things listed was "overfused condition".
Not sure what this meant. So no idea how to correct. So I called the inspector that did the inspection to get some clarification. He stated it was the range wiring.
There is a thing on the back of the range that reads just like this
Problem is, it is being fed with a 60a breaker and 6 ga wire. He said I need to change to a 40a or 50a breaker. Is that correct? I thought you size the breaker to the wire, and not the device?
If it had been an 7-1/2HP electric motor with #6 cable . The breaker would be a 125amp . So it all depends.
   / Electricians: Range wiring and breaker sizing code #78
The plan is to just put a 40 or 50 on there. Have no idea what it actually draws, never put the clamp on it.
More so, just curious if the way it is now is wrong according to current code requirements. (all though codes from 1995 would have to apply as that is when it was built.) OR, if the inspector is just wrong in his assessment.
Clothes dryer is a 30 amp breaker with a 14-30R receptacle. The stove will either be a 50amp with a 15-50R or a 60 with a 15-60R .
I am sure when an electrician is wiring a new build house, he has no idea what the range is going to be? How does he know if its a 40, 50, or 60??
Same goes for dryers and water heaters.
   / Electricians: Range wiring and breaker sizing code #79
:rolleyes:
- Jay
Olive oil, the kind Popeye would use on Olive oil when he was 'outta spinach! All natural, no synthetic.
   / Electricians: Range wiring and breaker sizing code #80
I think what they are telling you is the actual outlet box is rated at 50 amps. It should be stamped right on the outlet what it is rated for. So if the outlet is rated at 50A you cant use a 60A breaker, simple enough.
Better not be plugging a stove or dryer into that plug. In fact that plug is long obsolete. The only thing now that would be close is a 277V or 347V single phase receptacle .
2008 CHEVROLET C7500 BUCKET TRUCK (A51406)
2008 CHEVROLET...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
UNUSED PROFESSIONAL X2600A ELECTRIC CONCRETE MIXER (A54757)
UNUSED...
2011 TEM 50' FLARE STACK (A53843)
2011 TEM 50' FLARE...
ASCO Transfer Switch (A52377)
ASCO Transfer...
GMC 3500 Extended Cab 4WD Pickup Truck - 6L V8 Gasoline Automatic (A55218)
GMC 3500 Extended...
