Tachometer hour meter Stopped working - Yanmar 2310D
   / Tachometer hour meter Stopped working - Yanmar 2310D #1
Redlander
Member
Taabinga Queensland
Yanmar YM2310D
I need help please.
Last year a forum member kindly sent me a workshop manual for an almost identical tractor, YM276D
However I can't seem to find any info or where to look ... what may have caused the tacho/hour meter to stop working
Cheers
Bob (Redlander)
   / Tachometer hour meter Stopped working - Yanmar 2310D #2
I need help please.
Cheers
Bob (Redlander)
Is the tach cable drive? You may want to search this forum for past members that have had the same trouble.
   / Tachometer hour meter Stopped working - Yanmar 2310D #3
Your tractor has this gear unit mounted on the front of the front gear cover. You can see it on the top cut a way drawing on page 220-05-1 in your manual. Yanmar Tractor Parts TACHOMETER DRIVE UNIT I don't know just how hard it is to access the tach on the 276 but you probably need to detach the cable from the tach and see if it is ok. If you can turn it by hand while the drive end is still engaged it is broken.
   / Tachometer hour meter Stopped working - Yanmar 2310D #4
is it still firmly screwed into the back of the tac? mine got loose one time and the needle was jumping around like crazy. just a small little snug up and it was back to normal.
   / Tachometer hour meter Stopped working - Yanmar 2310D #5
This instance is most likely that the mechanical cable that rotates the tach is disconnected, or less likely, broken.
I'll add for somebody's future reference that I resolved a tach that was jumpy and screechy, by taking it out of the panel and dripping a little bit of graphite lock fluid around the rotating part where it enters the device. It has operated flawlessly in the two years since.
   / Tachometer hour meter Stopped working - Yanmar 2310D #6
I need help please.
Cheers
Bob (Redlander)
Can you take a snap-shot of the hour-meter to post here?
Polaris Ranger (A56859)
Polaris Ranger...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A56438)
2-Row Peanut...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
2013 FORD F250 (A60460)
2013 FORD F250...
FUEL CELL (A58214)
FUEL CELL (A58214)
