Posts Footings: What do you prefer?
   / Posts Footings: What do you prefer? #21
I'm no expert but if you were to trench, build footers for each post and then used form tube to bring the column up to grade. And use fasteners to transition to wood posts, it would seem to eliminate the issue with water retention rotting the posts.
I don't know how you would assure that the columns would not be damaged during backfill but you can probably figure that out.
Then you could include drain tile but I like the idea of trying to manage run off with surface grading.
If you do it this way, you might want to pour the tube and footing together or use rebar protruding from the footing into the tube form.
   / Posts Footings: What do you prefer? #22
Poles were braced by long 2x4's.Not that difficult.I know we should have taken a bunch of pictures.
My SIL, whom the barn was built for, is a structural engineer,so you know it was done right and according to code.
   / Posts Footings: What do you prefer? #23
Are you ever planning on putting in concrete for the floor? If so, then going stick built is going to offer other advantages for you if you are already going to spend the money on concrete? To me, it doesn't make sense to build with poles if you can have a solid foundation to build on top of.
Eddie
Eddie
What other advantages will stick-built offer?
Yes, this pole barn is going to have concrete. And the advantage to still building with poles is cost. Foundation cost more, stud wall will cost more, and really cant go 8' OC posts cause the wall wont handle ALL the load in those few locaions, so down to 2' OC trusses, which increases the cost of the roof BIG TIME.
   / Posts Footings: What do you prefer? #25
LD1
Not a big deal, to hire the rough framing and poles/trusses to be put in/up by a crew, lots of Amish Crews in the area that will do it for very little $.
My PB has 24" x 8" cookies under the posts.
The holes were ~42" by 48" deep.
the posts were put in with treated 2x6x24" nailed onto the post side at the bottom (reason for larger dia hole.) I would have liked them to be LAG BOLTED or THRU bolted in but 1000's (of pole barns) have nothing but a pole to hold them into the ground & weight of barn.
Doing the trench is not best way as others said, back a long time ago I had a pole barn thread and so far has been great.
I dug a perimeter drain 36" or so out from bottom outside edge, down & out into french drains I built.
The dig was not a square hole but one with one side steeply slopped back towards the barn. I put in sock covered tile in and then stapled dual layer of plastic to the barn skirt boards. The plastic 1st layer went into bottom of trench & had the tile laid on top of it. there was a layer of gravel (enough to just cover the tile) then the 2nd layer of plastic was laid back on top of gravel so it (water draining on plastic covered w sand& gavel) empties on top of the tile.
I capped the plastic with sand & landscape fabric layer of creek wash gravel and then landscape fabric on top of that gravel. The final layers are dirt/clay so ALL of it has some slope to move water away from barn & poles. I eventually added from 4" to 2 feet of fill along with the landscaping to move water away from the barn. Only thing I have FAILED at was getting spouting on the barn. Was going to be the next spring after it was framed in 2002, so far still is next spring 13 years later :eek: :/
old details
As for concrete it took almost 10 years for me to get my concrete in, needed the barn and saved to pay for the crete.
Mark
I thin that's what I am planning now. 2x6 or something around the base for uplift.
If only I could find an Amish crew to rough it out cheaply. I don't consider $5800 labor cheap for just rough framing and metal that shouldn't take more than 2-3 days with a crew of 2 or 3. Maybe I am wrong and that's the going rate. If so, I can handle the work just fine.
For me, it would be worth 2-3k to get framed and metaled. More than that, its worth the savings to do myself.
I like the plastic tapering down to the tile idea. I may do that but probably after the build. I assume you put the tile in lower than the bottom of the posts?
   / Posts Footings: What do you prefer? #27
The tile started out about 30" or so outside the barn perimeter and about 20" deep at that high side. it sank in depth but not a lot only enough fall to keep all the water flowing out towards the low side and into the french drains. The drains at the two lower corners are 30 or 40 feet out and sink to 5 or 6 feet deep. There are old cement blocks stacked in the bottom of the french drains and covered in landscape fabric too.
I dont like to put much of anything heavy close to the barn so depth is not much of an issue, BUT I think the concrete truck front tire crushed one of them cutting close in... :/ Never know if they are working other than it stays dry next to the barn.
The 2x6 on the bottom are good but like others said long time ago for hundreds of years people just stuck the poles into the ground and tamped them.
I also tamped the heck out of all my poles, used a 6' spud bar to tamp them all in. I managed to gain about 2 or 3 CF of dirt per hole weeks AFTER they tamped them in with jumping jack & compact foot. The spud bar has a 3" or so round flat end and a 3" chisel end on other end. 1" or so solid steel bar in between.
When we finish graded the inside of the barn a few weeks prior to the pour I added more sand/clay compacting mixture and used a story pole to level it to the 2nd floor. (Story pole is a pole cut/nailed to form a "T" you invert it and use it on the level 2md floor joists to level inside of the sand/clay then roll/vibe tamp.)
Mark
   / Posts Footings: What do you prefer? #28
Hard to beat a large footing down below frost. 3 to 4 times the size of the post is a good guide. Individual augured post holes are the best way to accomplish this. If you want to do a trench put in a standard footing and foundation wall. As far as drain work is there anyway you could put in a swale above grade out away from the building to divert water at surface level. this is cheaper and less maintenance if the site will allow for it.
Mark
And that would probably work in my case too. BUT....I dont want to spend 15k on a building, then have issues because I skimped out on $50 worth of lumber and an extra few minutes of work per post hole.
That, plus I think the framing and siding (what I was trying to hire done) will go up pretty quick. But was still gonna leave the one gable end open til concrete gets poured. Then finish it off.
That gable end points to the west. And with a 14' high building, and leaving 40' oped to the west....dont want uplift issues that can be averted so easily and cheaply.
This past summer, I actually saw a open sided animal shed blown over and laying on its back.
   / Posts Footings: What do you prefer? #30
It doesn't hurt to do some extra work to prevent uplift.
Are you sure that open shed run in was anchored with posts? Often they are built on runners and just sit on the ground. Some people like the idea of moving them like a sled.
Personally I have not fastened cross arms to the bottom of the post. But I have done it just below ground level on fence posts to prevent leaning posts.
I say if you want the extra support and assurance, go for it.
Did you decide yet whether to drill holes or make a trench?
2019 Doosan LCV6W Towable LED Light Tower (A51691)
2019 Doosan LCV6W...
UNUSED IRANCH IRMC HIGH END ELECTRIC MASSAGE CHAIR (A54757)
UNUSED IRANCH IRMC...
2025 TMA Attenuator Truck (A52377)
2025 TMA...
30007 (A53424)
30007 (A53424)
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54607)
2019 FREIGHTLINER...
