John Deere 2350 tractor under powered PTO need info on hydraulics on this
   / John Deere 2350 tractor under powered PTO need info on hydraulics on this #1
jgns1
Spencer's Island, NS
John Deere 2350
My neighbor has a John Deere 2350 tractor and had bought a woodsplitter to run off the PTO. The splitter runs okay but does not have enough power to actually split wood. How do I check to see if the fluid levels are sufficient to run the PTO, and I am assuming it's hydraulic, as I'm not a very mechanically minded person and actually have very little experience with this. Any basic help would be appreciated (diagrams even more so.) Thanks, John
   / John Deere 2350 tractor under powered PTO need info on hydraulics on this #2
Hmm - with pto's you would want to have the tractor engine running at pto speed to make the most of it. is the tractor running at pto speed? Also not sure what kind of pto splitter you have and what pump the pto shaft is connected to is he using ?
   / John Deere 2350 tractor under powered PTO need info on hydraulics on this #3
Hyd/trans oil dipstick will be by right heel when operator is sitting in the seat. Is there a control knob between the 2 gearshift handles? Does a pto hyd pump power wood splitter?
Thanks Radioman, yes the engine was running and revved up (I am assuming PTO speed). The splitter is one that he bought at Princess Auto (not sure of the brand name). It worked well last October...and this year not so. Can I post photos of it here for you to see better..like I say I'm not too mechanical on this, but another friend is. (actually asking this for him).
Okay, thanks..I know that the dipstick is located just behind the seat to the right of a filler cap, and opening that cap I see no oil at a level to see it, but there is oil on the clean stick (reinserted). Just wondering if the oil level is too low to completely power up the PTO to give the splitter the needed thrust to split the wood. We ran it yesterday while increasing the tractor rev speed so to increase the power to the splitter but it still does not seem sufficient.
Have to out for a small job, will try and post photos in about an hour (plus).
   / John Deere 2350 tractor under powered PTO need info on hydraulics on this #7
When checking the hydraulic oil have the tractor running (idling), just set the dipstick in, do not thread it on.
The tach should have a mark that indicates engine rpm for 540 PTO rpm.
I am not following why you need the tractor's PTO. Does it power a pump for the splitter? The problem may be with the splitter, not the tractor.
   / John Deere 2350 tractor under powered PTO need info on hydraulics on this #8
Small correction: 2350 dipstick has no threads on it as your 2030 but just sticks in the tube. Thanks for pointing out tractor needs to be idling to check hyd fluid level as I forgot to mention that.
   / John Deere 2350 tractor under powered PTO need info on hydraulics on this #9
Once we learn if this is a PTO powered splitter or one plumbed into the hydraulics of the JD 2350, we should be able to sort through his problem.
The 2350 has 55 hp on the PTO and 13GPM on the hydraulics, so shouldn't be short of power on the tractor end of either situation. ;)
   / John Deere 2350 tractor under powered PTO need info on hydraulics on this #10
trans oil dipstick isn't located close to hyd oil filler cap.
2013 Audi Q7 AWD SUV (A48082)
2013 Audi Q7 AWD...
2009 Chrysler 300 Sedan (A48082)
2009 Chrysler 300...
2016 SDLG L948F WHEEL LOADER (A51242)
2016 SDLG L948F...
2017 Ford Explorer XLT SUV (A48082)
2017 Ford Explorer...
2014 Dodge Charger Sedan (A48082)
2014 Dodge Charger...
2017 JOHN DEERE 624K-II WHEEL LOADER (A51242)
2017 JOHN DEERE...
