Sad reminder of the importance of welding
   / Sad reminder of the importance of welding #11
OR..... don't learn anything from the moral of the story.
   / Sad reminder of the importance of welding #12
True or not, it is a scenario that is no joke and not hard to imagine happening.
   / Sad reminder of the importance of welding #13
I had an acquaintance a while back, good man, tell me that when he had built himself a cherry picker for his truck to grab and load logs, he tacked it all together. Then he had a friend who was a good welder go through and weld it. He told me that he could weld, but he wasn't going to depend on his skills loading logs with it. I had to admire his common sense. He was a handy person- had a backhoe mounted on the back of an old truck cab. He had put a 4 cylinder car engine in an old tractor, transmission and all. He knew what he was doing. He took risks, but they were calculated - not from ignorance or overconfidence.
   / Sad reminder of the importance of welding #14
I can only speak for this local...but here you can't get a tag/registration for a homemade trailer without a DOT certified inspection...and they don't just check to make sure the lights work...!
Unfortunately where I am, they just want receipts for materials so they know how much tax to charge.
No inspection, no questions on who built it, nothing.
   / Sad reminder of the importance of welding #16
Yeah...A lot of places just want a weight from a certified scale... a shame...too many regs where they don't belong and not enough where they do...
   / Sad reminder of the importance of welding #17
Here the police check it to make sure it is not stolen. Then a SN is issued. Then permit and MVI. Nothing special about the MVI, just a normal trailer inspection by a mechanic. No weld inspections, no engineering checks etc. Its kind of a joke.
   / Sad reminder of the importance of welding #18
I always over weld just about anything that I work on, not because I don't trust my welding but I never liked the engineer that spec'd out the very minimum requirements for safety or load rating. I always put a little more than required unless there is a real reason for small welds like warping of the weldment.
I know my welds will always hold more than the steel I am welding to.
   / Sad reminder of the importance of welding #19
No doubt that trailer tongues occasionally fall off, or are wrenched off.
But that story is just a bit too melodramatic to be believable.
Agreed, story may be based on a true story, or 100% madeup or a mix. And no mention whether the safety chains tore off too.
This melodromatic writing on the internets must strike a chord because it's often imitated. Often fwd'd around in chain-emails, it's easy to spot.
Same here too, often no reason not to, if welding one side is good enough then weld both sides. There's often a way to weld things up such that the weld strength is a smaller factor of the overall strength.
   / Sad reminder of the importance of welding #20
Moral of the story anything anyone build or fixes can break and kill someone, even bran new cars from the factory - just ask Toyota, GM, Chrysler etc.
Bottom line, everyone can DO NOTHING, build NOTHING and never leave the house and life forever, well if you don't ever take a shower because you can slip and fall. OH and never use gas or electric because gas can explode and electricity can electrocute you.
Moral of the story - STUFF HAPPENS and you can't fix stupid.
UNUSED CFG INDUSTRIAL M-DRG MINI DIGGER (A51248)
UNUSED CFG...
LMC LOT NUMBER 10 (A53084)
LMC LOT NUMBER 10...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
Manac Walking Floor Trailer (A50322)
Manac Walking...
(INOP) BAD BOY ELITE SERIES ZERO TURN MOWER (A51247)
(INOP) BAD BOY...
