I Need To Know How To Time Ferguson TO-20
/ I Need To Know How To Time Ferguson TO-20 #1
FergusonFix
Sinton, Texas
Ferguson/TO-20
So, if the tractor wasn't out of time it is now. There, I confess, I might have made things worse then they were. Sorry. Ok? (LOL!) But really, I'm in need of instructions or links to video on details of timing the TO-20. Here's what I've done so far: At the compression stroke of #1 cylinder I rotate flywheel to 7 deg. BTDC, ............ after that I loosened distributor to listen for the spark but I hear none. If my procedure, thus far, is wrong, then, just tell what to do afresh. I am determined to fix this tractor for my dad. BTW, I believe the tractor has carb problems, too. But that's for another day. If anyone can set me in the right direction it would be greatly appreciated. P.S. I just have basic tools(no high tech please).
/ I Need To Know How To Time Ferguson TO-20 #2
Low tech--- Leave flywheel at 7 degs on compression stroke. Mark distributor housing at #1 with a mark. Then pull cap off see where the rotor is pointing to, should be point to the mark you made. If not pull housing up and turn rotor to get it to line up with the mark you made. Engine should start then set timing with a timing light. When you pull the cap made sure you have 9 volts or more on both sides of the points with the points closed. You have a 12volt system I'm guessing, but a standard point system runs on 9 volts. Try this and it should at least start.
/ I Need To Know How To Time Ferguson TO-20 #3
9v?
most of them old tractors were 6v!!!
and if points are closed. one side of them is ground. you won't measure any volts on ground. ;)
he said no high tech.. he din't say no tech at all! :)
/ I Need To Know How To Time Ferguson TO-20 #4
FergusonFix I didn't know the tractor was like the old fords. You might not be able to do it like I said, because of the more and some had mags.mI one was a fairbanks and i think maybe a wisco. Maybe sound guy well see this, he knows the fords inside and out, so hold tight for awhile and see if he see this.
/ I Need To Know How To Time Ferguson TO-20 #5
taking the dizzy cap off works just fine for lining up rotor to a coil tower .. don't really matter which tower is #1, as long as that wire goes to #1 cyl on comp stroke
/ I Need To Know How To Time Ferguson TO-20 #6
As I remember with my Fergie, you're supposed to take a small plate off the front of the bell housing and find the timing mark on the flywheel. I never had much luck with that, so I always just put my finger over the number 1 plug hole or, if you want to be high tech about it, use a compression gauge to determine when the engine is at TDC, or close to it. I've always managed to get it close enough so that I can adjust the dist enough to get it where it needs to be. I've never used a timing light or marks on it. It's not hard to do.
/ I Need To Know How To Time Ferguson TO-20 #7
agreed, it's usually esy enough to get close on at least the 2nd try for finding compression on #1... then seeing where the rotor is. then consult fire order and then populate the dizzy in the direction of engine rotation..
It is a 12 volt system. I did mark #1 on dist. cap. At one point, when flywheel @ 7 deg. on compression stroke, I pulled dist. cap off to see direction of rotor, I found it to be way off the marked #1 wire, but I was hesitant to assume this was wrong and correct it due to my lack of experience. Here's a question: Will TO-20's generally have #1 on dist. oriented the same or close? I ask because I have looked closely at videos of TO-20 wiring to get an idea of where our tractor's #1 should be. To establish #1. IF the rotor is indeed in the correct orientation(since it only goes one way)and is showing me true #1, then my original marks on the cap might be wrong. Right? I will try again asap to implement suggestions/procedures and truly appreciate all who are replying toward my query. Thanks again.
/ I Need To Know How To Time Ferguson TO-20 #9
you can take out a distribuitor and insert it so that any coil tower CAN be #1, as long as that coil tower has the rotor pointing to it on the com stroke
so looking at pics of others may not be helping you!
/ I Need To Know How To Time Ferguson TO-20 #10
also, any TO model is/was a 6v system. Someone converted yours.
Yes, I think trying to make my tractor's dist. orientation match those I've seen have been a problem for me more so than the timing issue at hand. That's me for you! I'm a real copy cat type of learner. Monkey see, monkey do(do)! Live and learn. As soon as I get another crack at the tractor I'll be checking where the rotor is and set my #1 wire/plug to it. Updates to come later. Thanks again!
Yes sir, I believe someone before us changed it to 12v system. Recently put a new 6/12volt starter but having problem with bolts on the rear end of it are backing out when starter is engaged. Any reason for it? Can thread locker fix it or is there a greater problem causing the bolts to get loose?
/ I Need To Know How To Time Ferguson TO-20 #13
You need to make sure the #1 cylinder is on the compression stroke. Pull the plug on #1 and hold your thumb over the plug hole as you tap the starter. When you feel pressure on your thumb, you are on the compression stroke. Now turn the engine until you see 7ーBTDC lined up with the notch in the timing window. The rotor should be pointing at the #1 plug wire position in the distributor cap. Next loosen the distributor slightly so you can rotate it. Stick a paper clip in the #! spark plug boot and hold it near a good ground. Rotate the distributor very slightly back and forth until you hear the spark snap. At that point your are statically timed. When you think you have it right tighten down the distributor.
/ I Need To Know How To Time Ferguson TO-20 #14
Got lock washers on them ? ...should be.
/ I Need To Know How To Time Ferguson TO-20 #15
The piston ( after you take the plug out) on the no.1 cylinder should be coming "up" for it to be on compression stroke. If you turn the engine by hand with a screwdriver in the cylinder,
it should be coming up and out of the cylinder, this is the compression stroke.
Just thought I'd add that in case you couldn't get your finger over the plug hole.
/ I Need To Know How To Time Ferguson TO-20 #16
if he can't get his finger to the plug hole.. he'll have a hard time with a screwdriver!
my feeler of choice for that work is a piece of 10-2 or 12-2 bared copper wire.. can't scratch cyl walls and is real soft if it gets somewhere it shouldn't
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
**SALVAGE ROW ENDS HERE** (A60430)
**SALVAGE ROW ENDS...
UNUSED 7" MINI EXCAVATOR TOOTHBED BUCKET (A60432)
UNUSED 7" MINI...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
2015 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A59230)
2015 Freightliner...
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
