suggested gear oil is SAE 90, but I can't find any
   / suggested gear oil is SAE 90, but I can't find any #1
nfernandez
Byron Center, MI
John Deere 2210
All, I went to my local TSC, and several auto parts stores and can't find any SAE 90 gear oil. I just purchased an older Ber-Vac 60" snowblower and it says the gear oil needed is SAE 90. Can I use something different?
   / suggested gear oil is SAE 90, but I can't find any #2
90 weight is actually 80w90:thumbsup:
   / suggested gear oil is SAE 90, but I can't find any #4
Usually you have some wiggle room for temperature variations, but your range is pretty narrow in winter.
75w-90; 80w-90 are very common & so long as theres adequate expansion room in the gearbox & mnfctr doesn't shun use, either should be fine if straight 90 is hard to find.
Thank you all for your help. Now for a followup question, how full do you fill the gearbox? I don't see a dip stick or window that shows how full it is. Attached is an image of the gearbox.
   / suggested gear oil is SAE 90, but I can't find any #8
Typically you fill it up as high as the hole that the square plug threads into. Once the gear oil starts spilling out of that hole, its full.
2005 JLG 660SJ Manlift (A54865)
2005 JLG 660SJ...
New/Unused Mini Crawler Dump (A54865)
New/Unused Mini...
KIDS DIRT BIKE (A53424)
KIDS DIRT BIKE...
VERMEER 605F ROUND HAY BALER (A51247)
VERMEER 605F ROUND...
Adams 5T High Clearance Fertilizer Spreader (A55301)
Adams 5T High...
2016 Ford F250 Pick Up (A47477)
2016 Ford F250...
