Kubota B21 Advice
   / Kubota B21 Advice #1
1savoy
Gold Member
Oklahoma
B26, ZD323-60 and JD JX75 currently. Previous: L3800 HST w/ BH77, JD301-A , JD450C Dozer, JD 330, JD F525, Ford 4000, Farmall H
Hey Guys,
I keep watching used B21's thinking one would be nice for my small 2.25 acres here in Texas. I have looked at a few in the $11,000 to $13,000 range and are pretty beat up. There is a really clean low hour (94 hrs) at a dealer I have been watching for a while. It started at $19,850 and every few months the price drops some more. It is currently at $17,850. What do you experts think? Still too much money for a B21 that stopped being produced a number of years ago? This one has the original 3 pt. arms still mounted on the loader frame and the original manuals.
Thanks,
Russ
   / Kubota B21 Advice #2
If you see some for $13,000 that are trashed, and you could get the nice one for maybe $15-16,000, it would be worth it. I believe the B21s were quite expensive new.
   / Kubota B21 Advice #3
I keep watching used B21's...
Have you looked at the B1700, B2100, B2400 series? IMO they are comparable to the B21 etc and can be found with low hours at reasonable prices...most have FELs but not often a BH...
Good Luck...
   / Kubota B21 Advice #4
I'm definitely not one of those "experts" you mentioned, so take my advice for what it's worth. Normally, I'd question why someone would need a construction grade machine like a B21 for a couple of acres, considering that they'll cost more than a similar size and horsepower CUT + backhoe and loader that would do essentially the same job in most situations. But your profile says you've had quite a range of other equipment, so you most likely know better than anyone what you want and need.
If the condition of the machine corresponds with the hour meter (tires, seat, seals, hoses, paint, etc.), $17850 is not a bad price.
   / Kubota B21 Advice #5
17-18k for a real real nice one is probably what it will sell for at a dealer. The size of the B21 makes it a very useful machine. If you had to sell it I 4-5 years and still had "low" hours and it was still in good condition, I imagine it would still be worth 14-15k.
   / Kubota B21 Advice #6
Having owned one now for a few years, I would highly recommend one. In fact, I have a web page documenting my experiences with it.
I do stuff with this tractor that folks with a lighter grade machine (non-commercial) would wince at, like slamming the FEL with tooth bar at an angle into rocky hillsides, then curl the bucket to break up the boulders and then haul them away. This tractor does not care. There's a reason it costs more.
If you get bored: B21
   / Kubota B21 Advice #7
Oops!!! You mean I am not supposed to do that with my BX25D? :laughing:
   / Kubota B21 Advice #9
I've had this B21 since new in 2004. Very useful. Nothing ever goes wrong. If you want a backhoe to shape up a 2.5 acre property, that lightly used machine looks like a good deal to me.
   / Kubota B21 Advice #10
I bought a used 2009 B26 in 2011 with 60 hours for $20,500 and it was pristine condition. I am the third owner and both second owner and I got great deals on this excellent machine. Other than a bit more engine HP, I think these are basically the same size machine. I am amazed at what I can do with it. You cant compare these TLB's with the B series compact tractors as they are way more robust than the B1700-2400 or even the newer B29XX series. Look at the specs and you will see thousands of pounds more weight on the B21/B26 TLB tractors.
You might get this one for $17K even or even less if you bargain with them, but the listed price with only 98 hours is pretty good. My deal was kind of a once in a life time price and I grabbed it up.
Mine does have a hydraulic thumb which after using it for about 300 hours, I wouldn't buy another TLB without one. Does the B21 have a thumb? That adds about another $2K to the price
2021 Deere 331G (A53317)
2021 Deere 331G...
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
43024 (A59228)
43024 (A59228)
2021 Ford Mustang Mach-E AWD SUV (A59231)
2021 Ford Mustang...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A55745)
2008 TEXAS BRAGG...
John Deere XUV825E (A56438)
John Deere XUV825E...
