BLOCK HEATER
   / BLOCK HEATER #1
rvpwop
fergus falls, mn
KIOTI DK45
WHAT to do for a block heater for new Kioti NX5010, any ideas?
   / BLOCK HEATER #2
I don't want to mess with the freeze plug style heater so I'm going with a lower radiator hose heater. AutoZone has them cheap according to TiogaJoe. My oil pan is not magnetic so that won't work. I may add an epoxy-on type pad heater. Several threads about this subject on TBN.
   / BLOCK HEATER #3
Go to your dealer and get a block heater made for your tractor. If it's a core plug type you'll have to drain the cooling system to install it and it's better than a lower rad hose type heater.
   / BLOCK HEATER #4
Do you also use a battery heater and/or fuel tank heater?
   / BLOCK HEATER #5
No I don't. I just use the block heaters on our Ford 4610 and the NH TD95D. In really cold weather (-20°F) it would be nice to heat the transhydraulic fluids but I haven't done that. The Ferguson starts up easy as it is a much lower compression ratio gas engine. I don't feel I need a battery heater because it always starts easier after ~ 3 hours on the block heater. I have the block heater on a timer and I feed the cows at 4:30 pm so the timer turns it on at 1:30 pm and goes off at 4:30 pm. I've not had any problems with gelled fuel so I do not have a fuel heater. Buying "winter diesel" for winter operation generally precludes that problem. May people have "summer diesel" in their tanks and that can jell at around 28°F and give you some difficulties. treating fuel with Power Service, et al additives or mixing in #1 diesel 2:1( two parts #2 to one part #1 ) can help that issue but having the right fuel is the best way to go.
   / BLOCK HEATER #6
I use an additive to prevent fuel gelling ever since I had to walk home once.
As to heaters my block frost plug type once failed and I tried a magnetic one that I picked up at a yard sale.
Six hours later and the magnetic one still would not heat enough to start the tractor while the frost plug unit would have done the job in 3/4 hr.
   / BLOCK HEATER #7
I had installed a $38 Kubota Canada block heater in my old B8200, and that made a world of difference in how easy it started and how fast warmup took. They tell me I won't be needing one in my "new" L3130, but if I think it will benefit from one, it'll get one. Heating the block is the way to go, IMHO.
1984 ASPT 30ft Pole S/A Towable Trailer (A51692)
1984 ASPT 30ft...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
377059 (A51572)
377059 (A51572)
2011 John Deere 7130 (A50120)
2011 John Deere...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
