Made a Pickaroon
   / Made a Pickaroon #11
Yeah the Utube video of the conversion from an axe is the one I based mine off. There are others where you can use a bolt and a piece of pipe. As far a using it's pretty easy, just swinging it into the wood it sticks and then you can lift it or move where you like. I've found it really good for getting would out of the back of the ute and also saving bending over when I'm using the hyd wood splitter. It's just a way of using the tool and not your back.
Here is my 8' one from a closet pole, a compression fitting from the plumbing shop and section of 1/2" all-thread.
No more crawinling up into the bed to unload. Use my short (36") LogRite hookeroon to just past the wheel wells than the 8' to pull rounds within reach of the LogRite. Speeds things up considerable and sure does save on the back.
Yes, that little "hook" on the end is the real secret to making a good one - it needs to be pointed back at the user by a little bit.
Use: need to move a round to the splitter? Hookeroon and roll it along without having to bend over or even touch it. Need to pick up some splits or small gauge rounds? Pickeroon and practice some "tossing" with it - sure does beat bending over, picking up a 'no split' piece and throwing it off the truck!!
Harry K
   / Made a Pickaroon #12
I have two of them I picked up at tractor shows and would be lost without them. I pick up all my bucked wood to be split with them and as mentioned above it's a back saver
   / Made a Pickaroon #13
I've seen them, but never used one. I depend on my pulp hook for getting the pieces I want. The tip is blunted with a hammer for better grabbing. Wood does not slip off. Use a torch or forge to heat the tip before peening it- easier.
   / Made a Pickaroon
Harry K
Nice one Harry, I like the extended Handel, is there enough weight in the end to stick the round and stop it from falling off? The weight of the one I made is just right however I don't have the same shape. I think I'll knock one up like yours on the weekend and give it a go, it would store better on the bottom rail of my hydrolic splitter.
   / Made a Pickaroon
Tcreeley, could you possibly post a picture of a pulp hook, I've never heard of one before. What dose the peening do, I've heard of that method welding cast iron.
   / Made a Pickaroon #16
For a long one, you need an light (wood or aluminum) handled and a bit of weight on the end. That plumbing fitting worked out perfectly weight wise.
None of mine, (2 logrites and this one) will "stick" in the wood and I wouldn't want them to. They aren't for picking up wood but for moving, dragging, rolling chunks. I have actually walked 50ft and back to retrieve my LogRite vice bending over and rolling a round 4' to the splitter :).
Harry K
   / Made a Pickaroon #17
I bought a hookeroon from Baily's and it is a real helper. Its like extending your arms and hands and gaining leverage at the same time.
A pulp hook lets you hold a log while moving your hand more to your center line, sort of the power spot. Tried to post a picture but failed -- someone will but also check google images.
   / Made a Pickaroon #18
   / Made a Pickaroon #19
Some of the things labelled hookeroons are actually pickeroons. A hookeroon has a hook to help the log stay on while you twist and pull it into position. A twist of the wrist knocks it off. Here's a modern and exaggerated picture of a hookeroon so you can see what I mean. The hook shown here is actually too big for simple wood handling so maybe it was used for a specific purpose.
2013 Vermeer BC900XL Towable Brush Chipper (A52377)
2013 Vermeer...
2017 Ford F-750 Altec LR758 58FT Insulated Bucket Truck (A52377)
2017 Ford F-750...
2016 CATERPILLAR 249D SKID STEER (A52705)
2016 CATERPILLAR...
2001 Subaru Outback AWD SUV (A51694)
2001 Subaru...
2009 John Deere 1050J Crawler Tractor Dozer (A52377)
2009 John Deere...
2018 Ford Fusion Sedan (A53424)
2018 Ford Fusion...
