What Loader will fit a 1993 Ford 3930 45 HP Diesel Tractor
   / What Loader will fit a 1993 Ford 3930 45 HP Diesel Tractor #11
I found this online of a 3910 with a 270tl loader.
It can certainly be done, I have seen quite a few of the CASE IH L360 being adapted to older farm tractors. Depending on the price it may be worth trying it.
Vanoostrums in NS was selling a bunch of NOS CIH loaders for that did not fit any current tractor, new loader for $2k something. I've seen a few mounted on well used older tractors.
I don't mind buying it but the problem is how do I know that it will fit. And I have bought from Burtons before.
I can get a good deal on Ford 270TL loader but I am not sure that will fit or that a 7310 would fit for that matter.
   / What Loader will fit a 1993 Ford 3930 45 HP Diesel Tractor #13
Why do you think a 7310 would fit on 1993 Ford 3930 Tractor. View attachment 396419
View attachment 396420View attachment 396421
Here are two 3930's with 7310 loaders, one 2wd one FWA.
1994 New Holland 3930 Tractors | JOE WELCH EQUIPMENT CALEDONIA, MN #39301465
1997 New Holland 3930 Tractors | Farm Sales & Service EAGLEVILLE, TN
The REAL issue is not if a 7310 will fit a 3930, but if the MOUNTS to fit a 7310 TO a 3930 are available. The 7310 fit a lot of Ford/NH tractors, I ran a TL100 that had a 7310 loader, mounts were not the same as the 7310 loader on a 5030 on the same farm.
Well, this is a Ford 7310 loader. And you are sure this will fit a 1993 Ford 45 HP Diesel Tractor?
I appreciate your due diligence on this matter.
   / What Loader will fit a 1993 Ford 3930 45 HP Diesel Tractor #15
You will have to ask the seller what mounts come with it and what model of tractor it came off. Appears from the photo that a set of mounts come with it, but the question is, for what tractor. You will need to measure and look at it in person to be sure. As I mentioned, the 7310 could be had with different mounting kits for different tractors.
   / What Loader will fit a 1993 Ford 3930 45 HP Diesel Tractor #17
I have a 7310 loader on my 95 MFWD 3930. I believe a 7410 will fit as well.
   / What Loader will fit a 1993 Ford 3930 45 HP Diesel Tractor #18
I saw those, at the time my tractor was far too small. Now I could certainly make use of one.
It you want a loader for a 485, they come up on kijiji once and a while, saw a complete 2200 for around $2500 once.
   / What Loader will fit a 1993 Ford 3930 45 HP Diesel Tractor #19
Ok, I used to have a 3930 FWA with cab and the dealer installed a 7310 loader on it. I do have to say though the hyd pump was ok for occasional use but not for real fast loader work.
   / What Loader will fit a 1993 Ford 3930 45 HP Diesel Tractor #20
First thing I see is that you need an adapter bracket for the tractor to accept the loader. The bracket will bolt to your frame in some fashion to support the loader. Without that the thing in the picture is useless to you. I bought one years ago from Koyker Mfg. (Koyker Manufacturing) for my JD. It was delivered to the house and was very reasonably priced containing everything needed to install. Plus it was made for that tractor, not some kind of gee I hope this will work. With you not having an adaptor, I think your best bet would be to look elsewhere. As I recall I did have to go to TSC and get a dual spool control and hoses for it. Then you would have to see on your tractor where to mount the control and possibly fabricate a mounting bracket. I don't see a set of controls with the one in your picture either.
Mark
Can you tell me if a 7108 loader can be mounted on a 3930
2007 International 4300 Box Truck, VIN # 1HTMMAAL07H360176 (A51572)
2007 International...
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
2005 John Deere L118 Automatic 42in Riding Mower (A51694)
2005 John Deere...
