Vintage vs Modern welders -- advice for a novice.
   / Vintage vs Modern welders -- advice for a novice. #11
So... we have vintage transformer based machines like the Lincolns pictured above vs a new PowerArc 200.
Nice looking old welders there, Derek. Are they both from the 50s? They look like it.
I started welding >40 y ago on old Lincoln transformer AC welders, and it was not easy. Years later,
I found out that it would have been much easier if I had decent dry rods.
Then I discovered DC arc welding.
I still have and use a stick welder, but I got rid of the old Lincoln AC 225 welders I had,
and replaced it with an older Miller Thunderbolt AC/DC machine.
My recommendation is that you pay a bit more for a DC box...it is far easier to strike an
arc. You can pick up an old AC buzz-box for $150, but an AC/DC can be found for $100 more.
Also, buy sealed rods...the 7018 1/8" Lincoln rods at HomeDepot are great.
I'd forgotten about the ac/dc part of the equation.
I'll definitely look for an ac/dc unit, rather than ac only.
The PowCon is DC only I think.
   / Vintage vs Modern welders -- advice for a novice. #13
Ka-ching ! 100.00 down and gone .... learn on the beast ( enjoy yourself ) and when something better comes along ... trade up ( and sell the old one to offset the cost)
baggie the unused rods ... and give'em 20 minutes on an old cookie tray at 200 in the oven before using them them.
   / Vintage vs Modern welders -- advice for a novice. #14
Don't worry about the powcon being DC only. They weld very nice.
My invertec v250-s tig/stick is DC only - it's only drawback is I can't tig aluminum with it.
   / Vintage vs Modern welders -- advice for a novice. #15
The PowCon welder I mentioned earlier... I called my neighbor and he wants $100.00 and it includes 2 50' leads, ground clamp, and chipping hammer, and yes it's working fine.
Probably a no brainer !
I guess it could even be considered vintage (at least a vintage inverter box).
At that price, jump on it. You would have a hard time buying the cables for that price.
Aaron Z
Waiting for a call back on the PowCon...
   / Vintage vs Modern welders -- advice for a novice. #17
Here's hoping you get it. The leads if not weathered will be worth the $100.... Terry
   / Vintage vs Modern welders -- advice for a novice. #18
I would look for a machine that doesn't have a few tapped settings, but continuously adjustable settings.
Like a thunderbolt, or idealarc, or dialarc.
I've read that Arc Products no longer supports PowCon... should that be a concern ?
   / Vintage vs Modern welders -- advice for a novice. #20
For that price, I wouldnt. You should be able to get your investment back out of the cables even if the welder dies.
Aaron Z
2006 Mercedes-Benz E350 Sedan (A51694)
2006 Mercedes-Benz...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
UNUSED JMR 40" HYD GRAPPLE BUCKET (A51248)
UNUSED JMR 40" HYD...
UNUSED 16" AUGER (A51248)
UNUSED 16" AUGER...
JOHN DEERE 560M LOT IDENTIFIER 15 (A53084)
JOHN DEERE 560M...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
