Rotary Cutter BushHog SQ720 blades not turning.
   / BushHog SQ720 blades not turning. #11
Forgive my ignorance, how do you check for the shearpin?
The PTO shaft from the tractor to the cutter is attached to the input shaft of the gear box. If the PTO shaft turns and the input shaft of the gear box isn't turning, then you've got a sheared shear pin.
   / BushHog SQ720 blades not turning. #12
Bingo!
OK, found the problem, The unit I have has a slip clutch and it was WAY TOO LOOSE, i could see air between the plates. i tightened everything up and she runs like a champ. Thanks for all the input and advice.
KENMORE 80 SERIES WASHING MACHINE (A54757)
KENMORE 80 SERIES...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 (A55787)
2016 New Holland...
2015 Komatsu PC138 (A47477)
2015 Komatsu PC138...
2012 Infiniti QX56 SUV (A55853)
2012 Infiniti QX56...
TRANSMISSION ON PALLET (A55745)
TRANSMISSION ON...
23169 (A50324)
23169 (A50324)
