TSC 6 ft rear blade
   / TSC 6 ft rear blade #1
oldpilgrim
Elite Member
SE Ma
2014 Mahindra 3016HST
CountyLine® Grader Blade, 6 ft. W - Tractor Supply Co.
anyone use one of these? I just got one and hope I didn't make a mistake. I'll use it for snow and occasional driveway smoothing out.
I went to the dealer where I got my tractor and his 6 foot version was offered to me at $625, list was $775. It didn't appear to be any better made to me either. It did have a way to tilt the blade that the TSC dosen't.
I'd like to hear your opinions on the TSC.
thanks
   / TSC 6 ft rear blade #2
You should be able to get some tilt by adjusting your top link. Whether it will be enough for your application will have to be seen.
yeah, I'm sure it will. The tilt feature was nice but not at twice the price.
   / TSC 6 ft rear blade #4
I bought one of the TSC blades last winter for snow removal, and it has worked just fine for that. That's all I have done with it. I use my Howse box blade for driveway work (it's the better tool for that in my experience).
   / TSC 6 ft rear blade #5
I bought one a few months ago and it is working fine for my needs . I have used it to level off some new lawn area , grade some driveway and just recently moving some snow . I have read where if you use it to hard they can bend so I welded some scrap channel iron on the back to help it have some extra strength , and so far no problems at all .For what it cost I am satisfied with it.
   / TSC 6 ft rear blade #6
I bought a 7' blade from TSC a few years ago mainly for snow removal. Worked good until I caught the end of the blade on something solid and bent it. I tried to straighten it as best as I could, but it was never right after that.
Another question....I've never used one before and I was wondering if leaving it in a float position would work for snow, or if that would cause it to rise.
   / TSC 6 ft rear blade #8
Old Pilgrim, I've had that TSC County Line 6' blade for my Kubota B2150 for about 10 years. It's a good value. I think it will be a great match for your tractor. :thumbsup: They make the same blade in a 7' length, but I think the moldboard is a bit light for that length due to the increased rotational force if you catch on something, as vulcancowboy did. I myself have seen two of their 7-footers bent pretty badly, one on a JD 955, the other on a Kubota L3200. Of course you can bend pretty much any blade if you're moving fast enough. Force = Mass x Velocity. :)
Not sure what you mean by leaving it in float position. To my knowledge, all CUT link arms float unless you've added hydraulic downforce, which would be unusual. It's not a very heavy blade, but I've never had a problem with it lifting up on me while moving snow.
I could let it down on the ground by opening the 'gravity' valve and let it set there with the position control lever down all the way. Or I could let it sit there with the valve closed which would make it not drop when it hits a lower spot. Thats what I meant by float.
Guess I'll just have to play with it. That's what's the most fun anyway. :)
   / TSC 6 ft rear blade #10
Yes, you want it to float for snow removal.
1272 (A50490)
1272 (A50490)
71067 (A49346)
71067 (A49346)
2013 PETERBILT 367 (A50854)
2013 PETERBILT 367...
2013 LONE STAR TRAILER MFG. (A50854)
2013 LONE STAR...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2017 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A49461)
2017...
