Tractor no. 15 !! It will be Cat yellow and have TRACKS !
   / Tractor no. 15 !! It will be Cat yellow and have TRACKS ! #171
One man's trash is another man's treasure.
   / Tractor no. 15 !! It will be Cat yellow and have TRACKS ! #172
Yep!
Although in Waldon's case, may be better said as "One man's trash another man can turn into a treasure".
ha,ha,
Todays pic shows the new mounting bracket for the snowblower. Next I will remove the old side extensions and build new ones that are 4 inches wider on each side. aaanewbracket1.jpg
   / Tractor no. 15 !! It will be Cat yellow and have TRACKS ! #174
Do ur tractors actually have 4x4?? And do u have a website with all ur tractors on it??
Only two of my little tractors have four wheel drive. I no longer have a website .
Todays pics show the wing extensions now built , installed and painted. Now it is 59 in. wide to match the rear tire width .aaaextensionpainted2.jpg
aaaafirsttimesnowblower.jpgThanks,
Yesterday I got the first 8 cab lights hooked up, today I will get the four overhead lights working.
Todays pic show the Ariens 2 stage snowblower I bought 3 years ago . I tweaked it to fit my jd 455 two wheel drive tractor . Now I will tweak it to fit my jd 455 all wheel steer tractor after I build the cab for it.
I added a hydraulic motor to turn the spout back and forth anewhydraulicmotor.jpg
dons4020frontwheelconversion.jpgLooking back the day I bought the jd 430 I already started putting larger tires on it. I attached new front spindles and the next day I built wheel adaptors for the larger rear tires.
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55301)
2012 KINZE FLAT...
UNUSED PROFESSIONAL X2600A ELECTRIC CONCRETE MIXER (A54757)
UNUSED...
2000 Mercedes-Benz S-Class Sedan (A53424)
2000 Mercedes-Benz...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
(APPROX 18) 2" X 6" X 68" TUBING (A54756)
(APPROX 18) 2" X...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
