Tractor no. 15 !! It will be Cat yellow and have TRACKS !
   / Tractor no. 15 !! It will be Cat yellow and have TRACKS ! #171
One man's trash is another man's treasure.
   / Tractor no. 15 !! It will be Cat yellow and have TRACKS ! #172
Yep!
Although in Waldon's case, may be better said as "One man's trash another man can turn into a treasure".
ha,ha,
Todays pic shows the new mounting bracket for the snowblower. Next I will remove the old side extensions and build new ones that are 4 inches wider on each side. aaanewbracket1.jpg
   / Tractor no. 15 !! It will be Cat yellow and have TRACKS ! #174
Do ur tractors actually have 4x4?? And do u have a website with all ur tractors on it??
Only two of my little tractors have four wheel drive. I no longer have a website .
Todays pics show the wing extensions now built , installed and painted. Now it is 59 in. wide to match the rear tire width .aaaextensionpainted2.jpg
aaaafirsttimesnowblower.jpgThanks,
Yesterday I got the first 8 cab lights hooked up, today I will get the four overhead lights working.
Todays pic show the Ariens 2 stage snowblower I bought 3 years ago . I tweaked it to fit my jd 455 two wheel drive tractor . Now I will tweak it to fit my jd 455 all wheel steer tractor after I build the cab for it.
I added a hydraulic motor to turn the spout back and forth anewhydraulicmotor.jpg
dons4020frontwheelconversion.jpgLooking back the day I bought the jd 430 I already started putting larger tires on it. I attached new front spindles and the next day I built wheel adaptors for the larger rear tires.
2024 CATERPILLAR 289D3 SKID STEER (A52705)
2024 CATERPILLAR...
2018 GEOBOY SITE PREPARATION MACHINE (A51406)
2018 GEOBOY SITE...
2007 FORD F150 XL EXT CAB TRUCK (A51406)
2007 FORD F150 XL...
UNUSED LANDHONOR RBP-13-72W 72" RIPPER BEDDER (A54757)
UNUSED LANDHONOR...
2018 JCB Truss Jib Telescopic Hydraulic Boom (A55787)
2018 JCB Truss Jib...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATE (A54757)
UNUSED LANDHONOR...
