Need quick info (continental post hole auger)
   / Need quick info (continental post hole auger)
I got the auger off. I tried banging on the bent spiral a few times and it appears that it may develop some cracks when I apply the breaker bar and wrench and bend it back into place. This has me considering a replacement auger from the get go. Will this unit run a 16" auger? It will be used in about as good of soil as you can get. I am also concerned about it having two bolt holes, as most of the newer ones I see only have one.
Here are a few photo's.
The top female end of the auger
The output shaft and two bolt holes
And the size of the output shaft
Here is where I think it will crack. I can probably weld and reinforce it, but if I am going to buy a new auger, I would like to replace it with something larger for telephone poles. that way I don't have two 12 inch augers should I be able to fix this one.
Could I just cut the lower 5 inch's of this thing off and redrill the holes for the tip, and cutting edges?
2023 Bobcat E32i Mini Excavator (A51573)
2023 Bobcat E32i...
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
Husqvarna YTH18542 42in Riding Mower (A51694)
Husqvarna YTH18542...
2004 CATERPILLAR D6R XL CRAWLER DOZER (A51406)
2004 CATERPILLAR...
22ft T/A Enclosed Cargo Trailer (A51694)
22ft T/A Enclosed...
2025 New/Unused Wolverine Pallet Fork Frame (A51573)
2025 New/Unused...
