Need quick info (continental post hole auger)
   / Need quick info (continental post hole auger)
I got the auger off. I tried banging on the bent spiral a few times and it appears that it may develop some cracks when I apply the breaker bar and wrench and bend it back into place. This has me considering a replacement auger from the get go. Will this unit run a 16" auger? It will be used in about as good of soil as you can get. I am also concerned about it having two bolt holes, as most of the newer ones I see only have one.
Here are a few photo's.
The top female end of the auger
The output shaft and two bolt holes
And the size of the output shaft
Here is where I think it will crack. I can probably weld and reinforce it, but if I am going to buy a new auger, I would like to replace it with something larger for telephone poles. that way I don't have two 12 inch augers should I be able to fix this one.
Could I just cut the lower 5 inch's of this thing off and redrill the holes for the tip, and cutting edges?
1982 S&S FLATBED (A52472)
1982 S&S FLATBED...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2013 Ford F-150...
2012 CATERPILLAR 279C2 SKID STEER (A51246)
2012 CATERPILLAR...
1997 Freightliner FL60 Truck, VIN # 1FV3GJBC6VH725847 (A51572)
1997 Freightliner...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A53473)
PENDING SELLER...
