A lost Asset in Auto Transmissions
   / A lost Asset in Auto Transmissions
Reading your first entry is about your vehicle spinning .
Read the title then twist it however you like. We knew what would happen when ask and I told what car we bought. I suppose that's just the nature of humans on forums and if I recall it has been established by the Admin. brand bashing isn't to be tolerated.
   / A lost Asset in Auto Transmissions #32
I'm kinda old school too...However, I have a 2013 GMC Sierra Denali and it has all of the computer fired crap that has been discussed...I will say that since it doesn't have any 4wd settings since it's AWD the traction control and the rest of the computer controlled stuff has worked to the point that I don't even realize it...I have 20" GY LS2 tires and have run through some pretty good snows and the truck performs flawlessly. ..
I live on an un maintained right of way and have an upside lot that is quite a few hundred feet up hill..No problems.
To reiterate, LS2's suck in anything but dry weather.
   / A lost Asset in Auto Transmissions #33
You didn't purchase a FWD NOX and then wonder why it spins? The wife's AWD Terrain with Michelin Ice X 2 tires will push snow with the front end while driving up hill.
Not at all. The post was about how auto manufacturers are screwing the usefulness of transmissions up. I'm real happy your wife's car can push snow up hill.
All right fellas.... first off, its not brand bashing. No one said anything about the brand.
Second off, the 2013 Equinox IS front wheel drive. See the link below:
2013 Chevrolet Equinox LS 4dr SUV 2.4L 4-cyl. 6-speed Automatic Features and Specs
Third, the vehicle comes with two transmissions, depending on engine. They are both 6 speed autos:
Hydra-Matic 6T45 that came with the 4 cylinder.
Hydra-Matic 6T70 that came with the 6 cylinder.
The 6T70 is a joint Ford/GM transmission project. Yes, Chevy meets Ford. See the link below:
GM-Ford 6-speed automatic transmission - Wikipedia, the free encyclopedia
So, SandburRanch, which engine do you have in your front wheel drive Equinox, the 4 or the 6? :)
   / A lost Asset in Auto Transmissions #34
Now look at page 9-28 of the 2013 Equinox owner's manual as linked to below. It explains how the manual range select mode works.
http://www.chevrolet.com/content/da...hip/Manuals and Videos/02_pdf/2k13equinox.pdf
You can only select which range of gears are available, not which gear the vehicle will use. So, you can select to start in 1st by knocking it down to 1. However, if you knock it down to 2, it will still start in 1, and shift up to 2 automatically when you hit the speed/torque that the transmission senses.
Every GM car or truck I have ever owned with an automatic transmission works this way. None of them will actually start out in 2. However, my current 93 Suburban, if I put it in 2, it will start out in 2. I just figured there was something wrong with my transmission! hahaha.
   / A lost Asset in Auto Transmissions #35
Brand bashing? What are you twisting now? How could I be bashing your Nox when we enjoy our Terrain ? If you had purchased an AWD NOX and proper winter tires, spinning would not be a concern. The problem is that you spent 95% of what was required then went cheap on the two critical components.
These are all the same vehicle platform with a different name on the fender.
Chevrolet Captiva
Chevrolet Captiva Sport
Chevrolet Equinox
Daewoo Winstorm
Pontiac Torrent
Saturn Vue
Suzuki XL7
GMC Terrain
Saab 9-4X
Opel Antara
GM Theta platform - Wikipedia, the free encyclopedia
Chevrolet Captiva
Chevrolet Equinox
Daewoo Winstorm
Pontiac Torrent
Saturn Vue
Suzuki XL7
GMC Terrain
Saab 9-4X
Opel Antara
Now you're beginning to get personal with your comments. Consider quitting while you're behind.
   / A lost Asset in Auto Transmissions #37
If your problems with your vehicle that you posted on this site is too personal ? Then just what exactly do you have in mind? Your 2WD vehicle without winter tires will tend to spin. Tis the laws of physics they are not personal.
   / A lost Asset in Auto Transmissions #38
Lots of vehicles, my pickup included, have Traction Control Systems that reduce power to the wheels if a slip is detected. It can be disabled if necessary. I wonder if this system works as well or better than starting in second gear?
You guys have no idea how good a well designed traction control system can be. The system on my Ford F150 rocks.
   / A lost Asset in Auto Transmissions #39
A manual transmission nowadays is the best form of anti-theft control. :)
   / A lost Asset in Auto Transmissions #40
I believe the point you are not understanding is that in the past, many automatic transmissions for 4wd and 2wd vehicles allowed you to start out in second gear. There is an advantage to this because in 1st gear, it is difficult to apply really low amounts of torque to the wheels with your accelerator pedal. It is very unforgiving. 2nd gear allows better low torque control. 4WD or 2WD doesn't matter. I have had 4WD vehicles stuck in snow that would spin all 4 tires but with careful low torque easing of the throttle was able to rock the vehicle out.
Traction control is of no value for this scenario because it doesn't kick in UNTIL wheel spin is detected. At that point, it is too late because even a minor or quick loss of traction microscopically melts the snow/ice and greatly reduces friction. Thus a very very GENTLE application of torque must be applied. Traction control is great for those who don't have a good feel for what is taking place or when loss of traction takes place while underway. I cannot make it up my unplowed hilly driveway with traction control on but can with it turned off. It reduces my torque too much to get a run up the hill and I have to powerslide around a turn in the process.
Give the man a break, who cares if he doesn't have a 4WD or snow tires. It doesn't matter if your stuck in the snow with 4WD or stuck in the snow with 2WD.
2014 FREIGHTLINER CASCADIA (A55745)
2014 FREIGHTLINER...
2018 Kia Optima Sedan (A55973)
2018 Kia Optima...
2019 John Deere 8295R Tractor (A53485)
2019 John Deere...
(APPROX. 20) 4' X...
2012 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTN6 LIGHT TOWER (A55745)
2012 WACKER NEUSON...
