Help with chosing rotary mower size
   / Help with chosing rotary mower size
Went and looked at the Frontier RC2060. It was pretty clean. Came off a JD one owner . Underside was nice...no dents. Blades could be touched up. The slip clutch was exposed to the elements because to cover was off the housing at the gear box. It was rusty. I dont know if that matters much. Hate to have no shear protection. Can a slip clutch be serviced.
   / Help with chosing rotary mower size #22
You have to service a slip clutch from time to time. Sometimes the linings have to be replaced. Just Google "Slip clutch adjustment" to get a load of good information.
   / Help with chosing rotary mower size #23
Yep, slip clutches need maintenance.
I still dont think the RC2060 is a good deal, unless they guy comes down a few hundred bucks. Considering you can get a slightly more robust cutter and warranty brand new for only a few bucks more.
I agree. It was a good place to start. I,ve decided to keep looking around? The wood Heritage HC60 seems to be a nice mower. I also looked at the ETA 5" mower. Seems very well built but not alot of feed back from many owners?
   / Help with chosing rotary mower size #25
I think it is a fairly new product, no news, is good news. Happy owners don't post on the Internet.
Everything Attachments 60 Inch Xtreme Duty Brush Cutter for Tractors with up to 75 HP
And there is an owner report on this thread: http://www.tractorbynet.com/forums/...ing-how-video-eta.html?highlight=#post3907386
   / Help with chosing rotary mower size #26
I like EA Equipment. I bought a couple of root rakes from them that work great!
   / Help with chosing rotary mower size #27
The only times I know that a large, or more important heavy bush hog creates a problem is when you are riding off camber, or sideways with the grade. The weight of the bush hog might encourage the tractor to slide sideways downhill.
   / Help with chosing rotary mower size #28
I would consider the cutter from ETA. I have looked it over and it looks very solid. It is priced right,as well. I would prefer it have a tube type single post tail wheel but the majority of smaller units use the a-frame type and they work just fine.
   / Help with chosing rotary mower size #29
Why the single tube?
   / Help with chosing rotary mower size #30
My HD bushhog 306 has the A-frame. My lighter duty model 105 has the square post.
Either is fine if done right
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A51039)
Neckover GL24-2-7K...
1994 PETERBILT 379 SLEEPER (A50046)
1994 PETERBILT 379...
2016 FORD F-250 SUPER DUTY SERVICE TRUCK (A51243)
2016 FORD F-250...
TEST BID LOT (A50775)
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
2022 Adams CLC-1013 Conveyor - New (A51039)
2022 Adams...
