Hook like attachment for holding top link up when not in use.
   / Hook like attachment for holding top link up when not in use. #12
How good are those tool cats??.
Very good! :D 4 wheel drive, 4 wheel steer, 4 wheel independent suspension, 61 horse power turbocharged Kubota 3 cylinder diesel. SSQA with aux hydraulics on the lift arms. Check my threads in the Toolcat Forum for more pictures: http://www.tractorbynet.com/forums/toolcat/
Very good on sidehills with the 7' brush hog. :thumbsup:
   / Hook like attachment for holding top link up when not in use. #13
I keep a separate top link on each implement so I don't need to adjust them or have one protruding from the back of the tractor. My DK35 came with a hook but I don't use it.
Perhaps you could use some eye bolt and cable arrangement to support the top link. Here is a photo of one I use to support my finishing mower drive shaft:
   / Hook like attachment for holding top link up when not in use. #14
I have a coil of 1/8" wire laying around the barn and just used a length of that to loop through a hole in a bracket on the ROPS, then bent the other end into a hook to hold the top link. I might take that off when I get a QH.
   / Hook like attachment for holding top link up when not in use. #15
A tarp strap works better than a bungee cord.
   / Hook like attachment for holding top link up when not in use. #16
Mine came with the hook... but once the hydraulic top cylinder was installed that hook was way too small.
Need to fab up something. Someday. I mostly have the backhoe on, so simply remove the top link.
   / Hook like attachment for holding top link up when not in use. #17
Hook a tarp strap to the OEM hook.
   / Hook like attachment for holding top link up when not in use. #18
I carry a couple of spare bungee cords hooked across the ROPS. Also use them to support the top link,
2015 Land Rover Evoque SUV (A53424)
2015 Land Rover...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A55218)
NEW 2025 Load...
2024 JOHN DEERE 6110M LOT NUMBER 56 (A53084)
2024 JOHN DEERE...
2007 PETERBILT 335 FUEL & LUBE TRUCK (A51406)
2007 PETERBILT 335...
John Deere (A50322)
John Deere (A50322)
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
