Whats needed to have rear hydraulics on 4700?
   / Whats needed to have rear hydraulics on 4700? #11
It would be right under this circled area just below and to the right of the seat if there.
Ah, yes I know the hydraulic block under there but I would just prefer to purchase the kit for everything. It will used to power more things than a hyd motor in the future.
   / Whats needed to have rear hydraulics on 4700? #13
Edward,
Before you put down your money on a SCV kit, does the tractor's main implement pump match up with the hyd motor? Pump gpm@psi => motor gpm@psi?
If the tractor has enough capacity for your application, you'll need a valve body that supports "continuous flow" and is an open center valve to tie into the tractor hyd system.
As kennyd mentioned Fitrite can likely help you out.
AKfish
   / Whats needed to have rear hydraulics on 4700? #14
If your going to run a hydraulic motor maybe a power beyond kit would be more suitable. Power beyond is used for backhoes and could also be used for hydraulic motors but you would need to add a way to control the motor.
   / Whats needed to have rear hydraulics on 4700? #15
Yup, he could plumb in a series of stackable valves from a power beyond circuit. But, the tractors hyd system might not have enough capacity for his hydraulic motor to work properly.
So, the next step might be a pto powered external mounted pump. Or, he could still go with tractor SCV's AND a pto pump.
AKfish
   / Whats needed to have rear hydraulics on 4700? #16
What size hyd motor are you trying to run?
Here is your hyd data.
Hydraulics:
Type: open center
Capacity: 6.8 gal [25.7 L] (gear)
8.8 gal [33.3 L] (hydro)
Pressure: 2500 psi [172.4 bar]
Valves: 3 optional
Pump flow: 9.9 gpm [37.5 lpm]
Total flow: 14.7 gpm [55.6 lpm]
Steering flow: 4.8 gpm [18.2 lpm]
You could add say a three spool valve in the back with float for T-N-T, and a detent motor spool for the hyd motor.
   / Whats needed to have rear hydraulics on 4700? #17
The third scv is available from JD. part #LVBM18820. my dealer list it for $280.50.
   / Whats needed to have rear hydraulics on 4700? #18
You need to have the 1st and 2nd for that that kit to work, it does NOT include a valve. The Mid-SCV kit actually has three valves, #1 and #2 are for the FEL, and that kit includes the lever, hardlines, ect. to operate the 3rd.
2015 GENIE Z-62/40 TELESCOPIC/SCISSORING BOOM LIFT (A52709)
2015 GENIE Z-62/40...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
New/Unused SD Lanch 20x20 Carport (A57454)
New/Unused SD...
LOT: Steel Work Bench w/Contents, 40" x 75" (A59076)
LOT: Steel Work...
