A lost Asset in Auto Transmissions
   / A lost Asset in Auto Transmissions #91
I wonder why there is "2". It must be for looks on the knob, making the driver think he has something he doesn't.
The way its described in my owner's manual is it limits the maximum gear the car can use, not the minimum. In today's modern cars with traction control, the main (possibly only) function of downshifting is to provide downhill braking. The transmissions will select the proper gear automatically for everything else.
   / A lost Asset in Auto Transmissions #92
Just check mine and 2nd stays in 2nd... no up or down and it doesn't matter if standing start or selected on the fly
   / A lost Asset in Auto Transmissions #93
Why ouldn't one simply apply brake pressure to modulate torque to the wheels in the absence of second gear starting ability and/or traction control? That's basically what traction control is anyway.
I don't remmeber any of the '80s and early '90s GM automatics I drove starting in second gear. We were all taught throttle control...and to use the brake to limit wheel slip if necessary.
   / A lost Asset in Auto Transmissions #94
Would work on a front wheel drive but not rear wheel drive for reasons I explained in my last post. Traction control doesn't modulate pressure the way I understand it. It has to first sense a wheel spinning then it applies brake pressure. As I also mentioned, it is too late once the wheel slips on ice.
   / A lost Asset in Auto Transmissions #95
This is correct. Also, for the above to work, the vehicle must have an anti-lock brake system. My 1995 tbird does not have anti-lock brakes, and I like it that way.
   / A lost Asset in Auto Transmissions #96
I forgot about that since they were all front drive cars or 4x4 trucks!
   / A lost Asset in Auto Transmissions #97
Exactly.
   / A lost Asset in Auto Transmissions #98
how do you manage that while drinking your coffee and texting mom to see what she wants you to bring home for supper
   / A lost Asset in Auto Transmissions #99
You can't choose which wheel to apply the braking to when you try to do it manually. The ABS will pick the spinning wheel faster than you can. At least, that's what they tell us. :laughing:
   / A lost Asset in Auto Transmissions #100
Everybody has traction control. Second gear isn't needed. Ford's traction control in snow and ice is really good as is Mercedes.
Eric, you keep saying that and I wish you wouldn't. We get it, you're good.
We aren't saying we need it, either. We're saying it used to be there and isn't now. Can't you understand that?
CAT FORKS W/ QUICK CUPPLER ATTACHMENT (A53843)
CAT FORKS W/ QUICK...
John Deere 5100M (A53317)
John Deere 5100M...
2013 MACK GU (GRANITE) TRI AXLE WINCH TRUCK (A55745)
2013 MACK GU...
2002 POLAR 150BBL TANKER TRAILER (A55745)
2002 POLAR 150BBL...
1993 Ford F700 Stakebody Flatbed Truck (A51692)
1993 Ford F700...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
