BX2750 blower - improvement to the manual chute rotate mount
   / BX2750 blower - improvement to the manual chute rotate mount #21
My blower (B2781A) came with a bracket very similar to the one you built. Had long bolts with it that would allow it to attach to the Hydro lines bracket. It's off now as I got lazy and bought the expensive($800) hydro chute rotator that uses the fel control.
That is what I'd really like to have, and now wish I had included it in the original purchase. But, as is the case so often, there was only so much money then, there is only so much money now. Every time I come close to having enough saved, something with higher priority comes up, and I begin again.
Great job on the bracket. Simple is good. By any chance, did you find the part numbers for the front and rear chains you bought from Pearless ? I would like to get a set for my Kubota BX2360 as well. Cheers.
If that question was directed at me, no, I still don't have the number. Just call Peerless with your tire size and explain your constraints on the inside. I should mention that the ones I'm using just barely fit in the long (circumference) direction. But they do fit.
   / BX2750 blower - improvement to the manual chute rotate mount #23
If you search you will find a windshield motor that can be used to turn the chute. It works well and if you buy a motor on EBay you can do it for $50.
Here you go
http://www.tractorbynet.com/forums/...hute-rotation.html?highlight=Snowblower+motor
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR29J160609 (A51572)
2009 International...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
1997 Freightliner FL60 Truck, VIN # 1FV3GJBC6VH725847 (A51572)
1997 Freightliner...
New/Unused 7ft 10 Drawer Work Bench (A51573)
New/Unused 7ft 10...
BESTWAY AG VSK50 LOT NUMBER 80 (A53084)
BESTWAY AG VSK50...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
