When will tractor manufacturers finally offer a front 3pt and implements for CUTs
   / When will tractor manufacturers finally offer a front 3pt and implements for CUTs #32
This hasn't been mentioned but a lot of tractors--well, at least my Kubotas--have pto stubs on the front of the crankshaft. I recall years ago lots of hydraulic things used to be hooked to them. Can't recall exactly but maybe mowers as well as hydraulic things. Maybe front mowers?
   / When will tractor manufacturers finally offer a front 3pt and implements for CUTs #33
I once considered adapting one of those Swisher mower decks to mount up front on my John Deere Gator 4x2. Use the winch to control deck height. It pushes a snow plow surprisingly well so it might work.
Not a three point attachment but seemed to work well in my mind.
   / When will tractor manufacturers finally offer a front 3pt and implements for CUTs #35
You guys are not looking hard enough, the front 3pt /pto offered by tractor manufacturers are supplied by the likes of Zuidberg and Laforge.
Zuidberg Frontline Systems B.V.
MK Martin also offers them. I would go Zuidberg.
Thanks for the link WilliamBos, I didn't find this manufacturer in my initial search. Just from browsing it looks like they make a ton of models for JD tractors.
   / When will tractor manufacturers finally offer a front 3pt and implements for CUTs #37
I know Mk Martin makes a front 3pt with a either clockwise or counterclockwise gear reduction kit to make the Mid-PTO reduce down to 540. They only make this for a few models unfortunately.
Even if I couldn't get front PTO setup with a 540 reduction, I could still see some uses for a front 3pt. Anybody how has ever tried to run a cultivator off a 3 point knows that this task is a P.I.T.A to try and keep the tractor straight and the cultivators out of the rows.
The 3 point looks like something like that might be easy enough to fabricate if one had a plasma cutter and good welder. As for the gear reduction PTO that might be a different story.
Those Vertrac tractors were similar to the old Toro Pro lawn tractor I used to work with. everything was front mounted and belt driven. I was always fabricating attachments out of the junk pile to make my job a little easier.
My uncle had a Farmall A, I think, that had a mid mount row cultivator that was raised and lowered by that weird midmount hydraulic arm they had, and my farmall cub had a belly mower that likewise was raised and lowered by the mid-"hydraulic" arm, but was powered by the rear PTO via a long belt and several pullies... Not fron mounts by any means, but way better thna rear mounts..
2017 John Deere 30G Mini Excavator (A50322)
2017 John Deere...
2011 Chevrolet Malibu Sedan (A50324)
2011 Chevrolet...
Case Ih 2388 Combine (A50514)
Case Ih 2388...
2012 Volkswagen Jetta Sedan (A50324)
2012 Volkswagen...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
