Buying a tractor - too many choices! Please point me in the right direction
   / Buying a tractor - too many choices! Please point me in the right direction #21
The G series list hydraulic lift control as "manual"
The R series lists hydraulic lift as "position/draft" What's the difference?
(With Kubotas-----) Manual hydraulic lift means when you lower implement it does not return to position it was in before being raised. It returns to position set my control lever. This is mostly an issue when using a Rotary Cutter. You would probably want to add Limit Chains to maintain an exact grass cut height. (See LINK.)
Position Control returns implement to exactly a pre-determined height, usually adjusted with a stop block locked by a screw.
Draft Control was part of the original Harry Ferguson designed Three Point Hitch, when plowing was a tractor's most important function. It is still important plowing, and helpful when pulling a full Box Blade. Reactive ground force compressing the 3-Pt. Top Link raises the implement when it runs into hard ground, a rock, or a Box Blade fills.
Plowing, Draft Control prevents the tractor from pivoting around the rear axle and going VERTICAL in 1/2 second when plow encounters immovable object underground. Box Blading, Draft Control usually prevents tractor from stalling out with full load in box.
Draft Control was $500 option on my Kubota L3560 in January 2012.
LINK: http://www.tractorbynet.com/forums/...ta-b3300su-zerco-check-chains.html?highlight=
   / Buying a tractor - too many choices! Please point me in the right direction #23
I just can't see how the 30ish horsepower G3033H at $17K can't get what I want done with extra to spare. The loader is rated at 1600 pounds and the unit weighs about 2600#.
I owned a Kubota B3300 SU, sames specs as G3033H above. Very light. Not stable enough for heavy work. Once you start to lift a wheel or two wheels off the ground regularly, it will only be a matter of time until you roll the tractor.
That 1,600 pound load is cantilevered way out in front. When one wheel drops in a rut, turtle den, hog wallow, that now unbalanced bucket load can roll the tractor. Worse on unlevel ground.
It is not a power issue, it is a safety issue.
I am older and do not heal quickly. I sold the B3300SU to someone who uses it to mow church grounds and bought almost same size but heavier, more stable L3560.
I have no idea what vehicle you drive but I advise no one to buy a tractor lighter than their truck.
   / Buying a tractor - too many choices! Please point me in the right direction #24
I don't think anyone has mentioned one attachment that I feel is VERY useful and I can't live without. And that is a grapple attachment on your FEL. If you have junk to move in the woods, you will really enjoy the grapple.
   / Buying a tractor - too many choices! Please point me in the right direction #25
I understand that you've already sized up your intended tractor purchase, but notice that essentially everyone who has responded has said to step up once more. It's well worth the difference in price.
Yeah, the guy that owned before me has a lot of "Junk" all over the property from various half-arsed projects that never saw completion. That's the first order of business actually. What would a used grapple go for? I assume it's a skid steer mount type?
Yeah, I'm getting that message loud and clear... Given that, Here's the few options that seem to be (tractor only) about 20-22K:
Kioti CK35HST
LS XR3037H
Kubota L3560HST
Those seem to be a step up and all well over 3K pounds. I'll have to get some prices, I guess, and go try them out in person. I guess then, when getting to this price point, it's going to come down to price out the door more than anything else. I'm not going to get one of the off brands like Tym as I want to make sure my dealer is still around. Maybe other options, too. I'll look into the 40HP+ prices of these as well and see where that goes. I'm not going to be able to get this done by tomorrow so year-end incentives go out of the window. It seems Kubota is already starting to leak their 2015 1Q specials as is Kioti so I'll just look for now and wait for a smoking deal. I was ready to pull the trigger on a G3033H but I'll do more research.
   / Buying a tractor - too many choices! Please point me in the right direction #28
I agree that bigger might be better for the OP, the LS G3033H weighs almost 50% more than a B3300SU....if you include loaders, it's an even bigger difference.
B3300SU weighs 1,930lbs and the LA504 loader is listed at 492lbs without bucket...total of 2,422lbs.
G30333H weighs 2,710lbs and the LL3102 loader weighs 1,124lbs without bucket...total of 3,834lbs.
Difference of 1,412lbs or 58%!
The two aren't remotely "the same specs."
   / Buying a tractor - too many choices! Please point me in the right direction #29
I doubt you would find a used grapple. But you can just add one to your bucket. And you will have to add a 'third function' hydraulics to your loader. Probably about $2500 for everything, but once you get it, you won't know how you ever lived without it. (Kinda like a cell phone).
Here is where I got mine, and I'm sure there are other places to get them too. Add-A-Grapple - Precision Manufacturing
   / Buying a tractor - too many choices! Please point me in the right direction #30
I've seen quite a few used grapples on Craigslist...mostly the standard skid steer type, but that would work. There are also a number of folks listing new grapples on CL that are pretty reasonably priced...this guy is selling new 66" models for $1400:
New 66"-84" Skid Steer Grapple Buckets
   / Buying a tractor - too many choices! Please point me in the right direction #31
I agree with the others here. Size up. I have 35 HP on my place (25 acres) and it works great. I would never go less though. Position control is absolutely essential. 20K will be hard. Of the tractors you mentioned, the only one I would consider for you is the L3560. It is a heavy tractor of the next class in 35 HP, and as I was quoted 30+K for one, 22K is a deal. I would look in at least high 40s HP wise. You can probably find something basic w/o busting your budget to much. I would bite the bullet and pay for a comfortable tractor HP and feature wise that will make you happy for years to come. Implements can come later at a cheaper price and as needed. If upsizing is totally out of the question, The CK35 has worked well for me. I would certainly upsize if at all possible.
   / Buying a tractor - too many choices! Please point me in the right direction #32
I bought my current tractor, Kubota 'Grand L' L3560 in January 2013.
Options: Greater lift FEL choice: LA805, Heavy-Duty Round Back Bucket L2296, Draft Control, R4 tires.
Finanaced with what Kubota terms 'O' percent financing + KTAC insurance.
$27,500 delivered (no sales tax on ag nor forestry equipment in Florida)
Wonderful tractor. 5,400 pounds/tires NOT loaded.
   / Buying a tractor - too many choices! Please point me in the right direction #33
No doubt about it, larger, a bit more HP, etc is most times good but not always. I was looking for a 50 HP tractor with cab and HVAC and FEL. My B.I.L. had bought a NH 2030 and it was a little light for handling round bales but with proper rear ballast it does the job. Anyway I looked at all the brands and then found the LS P 7010C for less or about the same as the 40-50 HP Kubota, JD, NH, Case and Massey tractors that I had looked at SOOOO, I bought the LS. It was very good for all the big stuff like pushing over trees, digging and hauling huge amounts of dirt, tree limbs etc but after about a year of working all the larger projects, I found that it was just too big for many of my projects and for finesse dirt work with the cab, it was almost impossible to see the front edge of the FEL bucket. I then started looking for something smaller to complement the big LS.
I found it with the help of a Northern TBN resident who had found a used Kubota B26 (26 engine HP) but had about determined that he was not going to be able to sell his B25 so he point me to the B26 seller. I bought it with just photos and drove the 500 miles to get it (after buying a trailer to haul it) and it was perfect. Only had about 60 hours on it and was still showroom perfect. $20,500 and it was mine. It is my go to tractor 99% of the time now. After more than 4 years, my 2010 year model LS has only about 110 hrs. but my 2009 B26 which I got in 2011 has almost 400 hours.
So the moral of this tale is, You can get too big for 99% of your needs and in most instances, that other 1% could still be done with a smaller tractor given more time and/or effort.
   / Buying a tractor - too many choices! Please point me in the right direction #35
Kioti CK35HST
LS XR3037H
Kubota L3560HST
Of those 3, the LS XR3037H will probably be the best overall deal. The Kioti CK35 should be cheaper, but I think it's missing some of the features that are included as standard on the LS XR series. The Kioti CK series is equivalent to the LS G series. (You have to step up to the Kioti DK series to get the same basic feature set on the LS XR series). The LS XR series is definitely a step up from the LS G series.
The Kubota L3560 is a REALLY nice tractor that includes Kubota's HST+ (which could spoil you very quickly). It does not include rear hydraulic remotes as standard, which are standard on the LS XR series and Kioti DK series. And it will probably be significantly more expensive than a Kioti DK or LS XR series tractor, especially when you add the cost of the standard equipment on the Kioti or LS.
Another possibility would be to follow Bart's suggestion of stepping up to the LS G3038 instead of the G3033 for probably not very much additional cost. The main difference in the G3038 and the XR3037 will be the extra features that are included as standard on the XR series, such as telescoping lower lift arm ends, rear hydraulic remotes, tilt steering wheel, etc. I suspect the additional features in the XR vs. the G would be well worth the cost difference.
Whatever you do, don't buy a tractor without a SSQA front end loader.
Thanks again. I had a long chat with the LS people. I like the features that are adding on the XR series including the rear remotes. For another $230, they'll add hydraulic tilt on the pto which would be a good reason to have the additional rear hydraulic. I've asked him to price me a XR3032 and a 3037 which are the same chassis and features -- just 5 horse difference. We'll see where that goes. Unfortunately, they don't have a 3032 or 3037 in stock at the moment as they have been cleaned out by end of year specials.
The rep did mention they have 8 each of the xr3032 and 3037h on order as they bought before a January price increase. Don't know how much or when, but apparently they are going up for 2015 models.
   / Buying a tractor - too many choices! Please point me in the right direction #37
With the US dollars at eight year highs, there should not be many price increases on imports.
   / Buying a tractor - too many choices! Please point me in the right direction #38
The XR series are very nice machines, with a lot of features for the money. Just as a reference point, a local dealer is under $20k for the 3032 and jst over $21k for the 3037.
LS XR3032H hydro tractor loader
New LS XR3037 tractor loader
   / Buying a tractor - too many choices! Please point me in the right direction #39
If you are considering the XR3032/37, then I strongly STRONGLY suggest bumping up to the XR4040 (or 46). The price difference will probably be at or under $2k. I know you're trying to stick to a budget, but here's why I think that for YOUR property, you should justify the jump:
Spec difference between 3037 & 4040
3pt lift, 1808 vs 2756 ... that's 53% more 3pt lift power.
loader lift, 2182 vs 2500 ... that's 15% more loader lift to full height.
loader breakout (strength at ground), 3420 vs 4354 ... that's 27% more breakout force.
wheelbase, 4040 is 3.4" longer (more stability).
weight, machine alone weight is 3567 vs 4334 ... that's 21% more weight (more stability and traction).
tires --- much MUCH larger tires, better traction & ground clearance.
You will likely be more productive with a stronger tractor, and you will not tax the limits of it's capabilities as often.
my thoughts anyhow... I'm on my 4th tractor in 3 years. I have learned & out-grown them. You might be able to just do it once if you do it right!
   / Buying a tractor - too many choices! Please point me in the right direction #40
TSO, that's why I like this forum. The experiences and wisdom of others is a great way to learn to avoid the same things happening to us, if we are open to learning.
That said, another thing I have realised is how darn easy it is to spend other people's money. But a few $k over however many hours of ownership is really a small price to pay for making the best choice, if that price is affordable to begin with.
Cheers.
2021 CAT 304E2 (A53317)
2021 CAT 304E2...
2007 Caterpillar 262C Compact Wheel Loader Skid Steer (A59228)
2007 Caterpillar...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2019 FORD F150 STX CREW CAB TRUCK (A59823)
2019 FORD F150 STX...
2015 TEXAS PRIDE TRAILER  30 FLATBED GOOSENECK TRAILER (A58214)
2015 TEXAS PRIDE...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
