Buying a tractor - too many choices! Please point me in the right direction
   / Buying a tractor - too many choices! Please point me in the right direction #11
i'm with motownbrowne size & wt are equally important as strictly hp. and the suggestion of extendable 3rd arm is indispensable for safety & time to hook up. the mx series can't be beat in the mid range hp tractor. imho a small utility tractor for your 60 acres would be ideal for future applications. would recommend loading rear tires. used is an option, not sure how financing works on that. & get those pics out to the forum once it's a done deal. my suggestion is don't move too quickly in the buying fever, ball's in your court. sleep on it.... best regards
   / Buying a tractor - too many choices! Please point me in the right direction #12
Do you have any experience with tractors, if not or it's been a while, you might want to go rent something in the general size range or really any tractor for a weekend to get a baseline for comparison.
Tractors seem to shrink and lose power once you get them and use them a bit. In 2008 after owning several tractors, I decided I need another one to keep from running between farms. I went looking for a 35HP machine and my wife talked me into a 50HP and I sure was glad she did.
Most of us go through the same thing you are when buying and sure empathize with your dilemma; good luck.
   / Buying a tractor - too many choices! Please point me in the right direction #13
How can something so enjoyable be so stressful!!!! ;)
   / Buying a tractor - too many choices! Please point me in the right direction #14
Make a map of tractor dealers within a range of 50 miles. Go to these places and sit your butt in as many tractors as you can find. Talk to the dealers but do NOT buy yet. At home write down your likes and dislikes about each dealer and tractor. Add it up and your tractor will come to you. Enjoy the hunt and the Victory of the find. Whatever you do DO NOT price your machine after you buy!
   / Buying a tractor - too many choices! Please point me in the right direction #15
Will you want to operate your tractor on all 60 prospective acres?
That is a lot of ground for a light tractor like Kubota B3301, which will only pull five foot wide implements.
If less than 60, how many acres will be tractor-active? How about slopes? What type of soil?
All tractor Three Point Hitch PTOs operate at 540 RPM. A few are two speed, 540 RPM + 1,000 RPM.
   / Buying a tractor - too many choices! Please point me in the right direction #16
Wise words Murph, wise words. Especially the last sentence. Never look back.
   / Buying a tractor - too many choices! Please point me in the right direction #17
I believe weight is more important that HP for most tractor tasks other than for hydraulic and PTO related tasks. It provides stability and better traction when doing ground engaging work like working a box blade, ploughing, and front end loader (FEL) work. Even though I'm a gear tractor kinda guy, I think HST is perfect for your application.
I also believe that you should scrap buying new impliments spend that money on buying as much tractor as you can and buy used impliments as you need them (been there, done that and got the t-shirt). Shoot, you can even rent things like post hole augers (more economical). The FEl on the 3038H lifts 1900# v. 1600# with the 3033. Weight is about the same.
You won't go wrong with an LS Tractor. I have one, a couple of friends have them and none have had a problem other than the fuel guage showing 1/4 tank when actually empty. You don't see many complaints here about them either. Does that size come with telescoping lower links?
I made a list of "Must Haves" and a list of "Wants". In order for a tractor to be considered, it had to have all the "Must Haves" then I weighed price against the "Wants" and came to my conclusion and bought my tractor sight unseen. i also read every review I could find and watched every YouTube video I could find on them too!
Thanks all for the feedback. In the "size up" argument, I've already come up from considering something like a J2030HST so I've already sized up once. It seems it's never ending... Each step up brings another feature I'd like to have! That said, I won't be working much of the land to speak of. I'll brush hog around the tanks (two of them totaling about 3.5 acres), brush hog the trails leading across the property being accessed by 4-wheeler, and maintain the road into the property which is about 400' to the area set aside for water/septic/electric. In that area (total of .8 acre or so), I'll mow it with a ride on. There are enough fence posts that are bad that it will be worth getting an auger to make that job a lot easier. Over time, I'll probably make the "trails" across the property into narrow "roads" that I will access with 4wheelers and/or off-road golf carts. I just can't see how the 30ish horsepower G3033H at $17K can't get what I want done with extra to spare. The loader is rated at 1600 pounds and the unit weighs about 2600#. There are equivalents in this size in JD, Kubota, and Kioti nearby as well and I can look at all of them and will do so very, very soon as the property closes in 3 weeks and I'll need to get started as soon as I can make a decision on the hardware.
Thanks for the feedback for testing each one as I hadn't really considered that part. Ergonomics are important, no doubt.
As far as telescoping lower link, at least in LS, I think I'd have to go to the R series instead of the G series. Big jump up to 39 horsepower, and price...
Another question:
The G series list hydraulic lift control as "manual"
The R series lists hydraulic lift as "position/draft" What's the difference?
   / Buying a tractor - too many choices! Please point me in the right direction #19
Position control means that the lever will go from say 1 (lowest position for the 3pt arms) up to like 9 (highest position). If you put the lever at any of the increments, it will lift the arms (or lower them) to that position. The other option is usually "valving" and the lever moves the arms up or down in small increments with each lever movement, forward or back. But, you can't just jump to position "3" because it doesn't know position... It can only take baby steps up or down.
But I think the G series is all position control.
Personally, for the size property, you should be stepping up to the larger frame CUT'S, 40-60 HP. If you buy smart, you may only have to buy once.
You can likely get an XR4046 HST with loader for around $22k. Good tractor for the money! Will come most deluxe options like SSQA plate on the loader, two sets of rear remotes, draft control, telescoping 3pt ends AND stabilizers.
Like others have said, buying NEW 3pt non-mechanical implements is usually a waste of money. You should be able to find a good used 6ft box blade for under $400 & a good 6ft brush-hog for under $500.
Good luck!
   / Buying a tractor - too many choices! Please point me in the right direction #20
I'll say this from practical experience. And I'm not yelling at you, just want you to get the importance of this point..... GET POSITION CONTROL 3PT, DON'T CARE WHAT IT COSTS!!!!!!!!!!!!
2020 DRAGON ESP...
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
2007 Yamaha Rhino 660 (A56438)
2007 Yamaha Rhino...
2006 TerraGator 8104 (A56438)
2006 TerraGator...
2013 Ford F-250 Pickup Truck (A55973)
2013 Ford F-250...
1984 Trailmobile Enclosed Van Trailer (A55315)
1984 Trailmobile...
