Home-made mini tractor 4*4 with the joint joined frame
   / Home-made mini tractor 4*4 with the joint joined frame #71
Thanks for all of your videos. Your craftsmanship is amazing.
   / Home-made mini tractor 4*4 with the joint joined frame #73
Definitely a thread I will have to come back too. Lots of great idea in just the first video I watched.
Additional panel of devices
   / Home-made mini tractor 4*4 with the joint joined frame #76
6 volt system - correct ? Nice big alternator and battery.
The white plug you show sitting on the left side of the panel - is that for supplying power to someting external to the tractor, or are you using it as a shorting shunt ?
I like that phone cable routed on the control rod.
With your lights, you'd be more road-legal than most ATVs that run around here !
The external tank beside the battery - what is in that ? What are those 2 lines in the red funnel ?
Looking good :thumbsup:
Rgds, D.
   / Home-made mini tractor 4*4 with the joint joined frame #77
Amazing Machine,good Job
Rgds, D.
There 12 volt, a voltmeter is megascopic a resistor.
White shteker for the lamp of external illumination.
External tank for expansion of cooling liquid
There are voice Warners of turns in a red crater. Funnel is strengthened by a sound
   / Home-made mini tractor 4*4 with the joint joined frame #80
Interesting - over here I would not expect liquid cooling on a 2 wheel tractor; but I have seen enough of your work now to picture you adding your own liquid cooling if it was not original.
I know how critical the acoustic enclosure design is for piezo drivers (for alarms) - that is neat what you did with the funnel.
Rgds, D.
2016 Husqvarna YTA22V46 46in Riding Mower (A56859)
2016 Husqvarna...
2012 UTILITY REEFER TRAILER (A58018)
2012 UTILITY...
2010 GMC Acadia SL SUV (A56859)
2010 GMC Acadia SL...
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
2022 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A56858)
2022 Chevrolet...
2013 Chrysler Town and Country (A56859)
2013 Chrysler Town...
