GManBart
Elite Member
- Joined
- Dec 10, 2012
- Messages
- 4,976
- Location
- Detroit, Michigan
- Tractor
- Massey Ferguson 241, Kubota SVL90-2
If you are considering the XR3032/37, then I strongly STRONGLY suggest bumping up to the XR4040 (or 46). The price difference will probably be at or under $2k. I know you're trying to stick to a budget, but here's why I think that for YOUR property, you should justify the jump:
Spec difference between 3037 & 4040
3pt lift, 1808 vs 2756 ... that's 53% more 3pt lift power.
loader lift, 2182 vs 2500 ... that's 15% more loader lift to full height.
loader breakout (strength at ground), 3420 vs 4354 ... that's 27% more breakout force.
wheelbase, 4040 is 3.4" longer (more stability).
weight, machine alone weight is 3567 vs 4334 ... that's 21% more weight (more stability and traction).
tires --- much MUCH larger tires, better traction & ground clearance.
You will likely be more productive with a stronger tractor, and you will not tax the limits of it's capabilities as often.
my thoughts anyhow... I'm on my 4th tractor in 3 years. I have learned & out-grown them. You might be able to just do it once if you do it right!
...another thing I have realised is how darn easy it is to spend other people's money. But a few $k over however many hours of ownership is really a small price to pay for making the best choice, if that price is affordable to begin with.
Cheers.
Yes, Yes it is.
Let me back up a little. This started as a step up and we're now pushing into $30K territory as each step up brings another "well, if you are going to step up to that, you might as well step up to this"...
Facts:
-57 acres. Only 1 is lived on. The rest is 75% native pasture with some small evergreens here and there. The remaining 25% is mature oak. 3ish acres of pond exist.
-I will not be cutting hay, planting rows, or any other heavy agriculture. This will be a "hobby farm". I'll do the minimum to keep my Ag Expempt status and nothing more
-Once a few of the heavier things are done, I won't need anything more than a bush hog and a box blade as I'll let the pasture grow wild except for mesquite.
-If I get into 30K territory for a tractor, that pays for basic land maintenance for a LONG time and a little bit at a time.
-I just want to have fun on the land and doing some moderate work. If it gets to be too big of a job, I'll bring someone in so buying enough tractor is probably less for me.
On here I keep hearing size (weight) and features are more important than overall HP. The XR3032H here is 19,850 or so compared to 17,240 for the G3030H. I can probably get it down a little as I haven't even started bargaining. They sell implements rather inexpensively compared to what I can find used. $5xx for a 6' box and 6' brush with the tractor. About $600 all in for the auger and blade. This is still close to striking distance of my original under 20K budget (before tax) and isn't yet out of hand. Of course I could jump to the 3037. But if I'm going to do that, the 4040 is a better idea as it's not much more... but then if I'm going to go there, why not the 4046? I have to stop somewhere on the step up and decide that I have reached "good enough" for my needs. Is there some reason why a 3032 or 3037 isn't enough for what I've stated above?
I purchased my bobcat CT 225 with loader brand-new for 14,000 on closeout it is essentially the same as the kioti CK 27. I too was torn between the larger DK series but am very pleased with my choice. It has done everything I've asked it to and exceededmy expectations. Grapples are cool but I have found forks quite useful as well and much cheaper to purchase. As others have said make sure whichever way you go you get the quick attach bucket.
Yes, Yes it is.
Facts:
I can only load one pic at a time for some reason
No Tom he had a bunch of them. Thy did sell fast though. I'm very happy with it I feel it's a great size tractor for me. No complaints.
First the closest dealer is about 45 minutes - Kubota. Another half hour will get me to LS, John Deere, New Holland and Kioti... If I'm willing to go a couple of hours, I can get just about every major brand. The closest, by far, is a Kubota dealer at 30-40 minutes drive. I'm closing on 60 acres in about 30 days and there's an immense amount of work to be done. I won't be doing any planting, hay cutting, etc., as I'll be moving from Ag Use to essentially enjoyment of the land with a Wildlife Exemption. That will require some basic work such as brush hogging, road maintenance, fence work, and lots of cleanup work on old, dead trees, junk left out in the woods, and so on. I'm thinking I can get away with a 30ish horse but I want the weight so I can box blade the crappy driveway and roads into something more usable. I'll have road base delivered and I'll slowly work on a road across the property to the back. All total mabye 2000' of road built over time. (lots of time)
I've honestly done a ton of research and come up with the following list of things I think I want:
30ish HP tractor with FEL
Hydrostatic
R4 Tires
3-point Quick Hitch
Brush Hog implement
Box Blade implement
12 auger for some fence post repair (quite few of them are rotten or just poorly done)
540 PTO
Now... Some of the things I don't understand yet. Do all the 3-points on these CUTs hydraulically raise/lower as I've seen in "how to" videos or is that an "option". How important is weight going to be for my uses? There's a significant difference in weight in some of the CUTs. I'm assuming with FEL work, chassis weight is quite important.
I'm looking to keep the above package from getting over $20K. I really like the feature set of the LS G3033H and with implements above in a package, I'm in around that price or a tad over. I guess I'll leave at that and await a few points of advice and come back with more questions.
Thanks for all the help, in advance.
