Hydraulic pressure check
   / Hydraulic pressure check #1
bobsphotos
ME
JD 3320 Ford 641 Ford 861 Kubota L3400
Morning,
After a piston pump rebuild I would like to check how much pressure it is putting out. Where in the system can I check it? My plan was to plump a gauge into the plug on the side of the pump but I am not sure that will show full pressure.
Thanks, and happy new year.
Bob W
   / Hydraulic pressure check #2
Make sure you check it after the pressure relief valve. Just the voice of experience here.
   / Hydraulic pressure check #3
Morning,
Bob W
You plumb your gage in a tee in the IN port of the first valve, and it will show the pressure developed by the cyl or motor.
If you know the rating of the hyd pump, you can do or have done, a flow and pressure test where they use a pressure gage, a flow meter and a needle valve.
You need to know pumps max pressure so you can set the relief valve slightly below that pressure.
   / Hydraulic pressure check #4
You check the pressure before the relief valve. The relief valve is what sets the relief pressure.
You can check pressure for any valve by using any of the QD on the machine using a plug in gage and using the levers briefly.
   / Hydraulic pressure check #5
What happened and I was really green I just installed a pressure gauge to the outlet port if the hydraulic pump. After all that should tell me the pressure that it develops right? We ended up going and getting a new pump.
Hi guys,
I should have mentioned that this is on a 1959 Ford 641. There are no QD's. This tractor only has a 3 pt hitch and no external hyd plumbing.
Bob W
   / Hydraulic pressure check #7
Do you have an I&T or some other type of service manual for the tractor? They usually show where to check pressure. Maybe someone who has one can let you know.
I have 2 different manuals but did not think to check them. Thanks for the idea.
Bob W
Thanks pmsmechanic for the idea. One of my manuals talks about where to check it.
Bob
   / Hydraulic pressure check #10
Hi guys,
Bob W
I was waiting till you finally told us what tractor this was.
As for no hyd plumbing, sure it does.
2 options that are easy.
Have a 3000 psi gauge, and either put it into the port on the pump body with a plug, or , my favorite, in the plugged port on the 3x5 cover under the right front of the seat.
Then chain the upper lift arm, either side, thru the knuckle, and to the axle.
Next exercise the 3pt lift and observe the gauge. You should see hyd cracking pressure, make sure rpm is at least at mid throttle. Engine will bog when forcingnhyds past relief.
2022 CATERPILLAR 317 EXCAVATOR (A51246)
2022 CATERPILLAR...
2024 JOHN DEERE FC20M LOT IDENTIFIER 53 (A53084)
2024 JOHN DEERE...
PALLET OF ARMSTRONG CEILING INSULATION (A51248)
PALLET OF...
LOT IDENTIFIER 234 (A53084)
LOT IDENTIFIER 234...
UNUSED CHERY INDUSTRIAL 14' BI-PARTING IRON GATE (A51248)
UNUSED CHERY...
2023 LandHonor RB-14-72W 72in Rock Bucket Skid Steer Attachment (A51691)
2023 LandHonor...
