3-Point Hitch Short Sub Soiler?
   / Short Sub Soiler? #1
jlgurr
Bostic, NC
Massey Ferguson GC1705, John Deere STX46
Borrowed a friends sub soiler to use on my GC1705, It was too long and was already digging with the three point lifted as high as it will go. Do you know if there are shorter subsoilers to use on the smaller tractors. Was able to slightly modify my buddies Sub soiler to finish my water line burying project. Would prefer one that fits my tractor if I buy.
Thanks,
Jeff
   / Short Sub Soiler? #3
Are you able to shorten your lift arms any by using a different mounting hole? What is the style sub-soiler that you have? I ask because some can be adapted to have the hitch pin sit lower on the implement and that effectively raises it when it's mounted. Not sure what style you have but there might be different size points that again, effectively raise or lower the implement.
   / Short Sub Soiler?
   / Short Sub Soiler?
Hey Sixdogs,
The lift arms on this machine are fixed length. The subsoiler we used is a Fred Cain model. Built very stout too, I might add. For a taller tractor I am sure it would go through just about anything you wanted to dig up.
   / Short Sub Soiler? #6
Hey Sixdogs,
I'm not sure you can do it with a Fred Cain model but I did it on a different ripper that I have. This one of mine is a real beast and I use it with a smaller Kubota in cat I or bigger Deere as cat II. See photo below.
I added a plate to the sides and spaced the pins roughly 5" or 6" apart. By lowering the cat I mounting you raise the implement. You can also get a shorter point for additional effect.
   / Short Sub Soiler? #7
King Kutter makes a subcompact sized subsoiler/middle buster combo attachment. I bought one recently, but can't comment on effectiveness as I haven't used it yet.
   / Short Sub Soiler? #8
I added a plate to the sides and spaced the pins roughly 5" or 6" apart. By lowering the cat I mounting you raise the implement. You can also get a shorter point for additional effect.[/QUOTE]
Good idea using extra set of pins to change the depth!
   / Short Sub Soiler?
That's a neat idea and you are correct. It wouldn't work on this Fred Cain model...
   / Short Sub Soiler? #10
my neighbor bought a subsoiler to bury some irrigation pipe but his j.d. x585 was too low. I let him use my I-match & it gave him just enough lift not to drag the point. its worth a try if you have access to a quick hitch. good luck.
2015 Dodge 5500 4X4 Bucket Truck (A51039)
2015 Dodge 5500...
2013 Chevrolet Silverado 3500HD Crew Cab Omaha Service Truck (A48081)
2013 Chevrolet...
2013 Big Tex 16GP-20 Gooseneck Trailer (A50860)
2013 Big Tex...
5K ANNULAR BLOWOUT PREVENTER (A50854)
5K ANNULAR BLOWOUT...
Unused Auto Darkening Welding Helmet (A49346)
Unused Auto...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A51039)
Neckover GL24-2-7K...
