Buying Advice ck dk trade
   / ck dk trade #12
I traded my 05 CK30 FEL w/backhoe (450hrs) +$10K for a DK40 FEL a year ago. Wish I had kept the CK.
   / ck dk trade
Gotta tell us why IXLR8
   / ck dk trade #15
My number was just a guesstimate, but if the CK is tier 3 it might be a plus for it. Can't hurt to ask though.
   / ck dk trade #16
I had R4's on both tractors but the DK's tires are more aggressive and have less surface area, coupled with the fact the DK is heavier, it tears up my yard more. I wish I had gotten the 'turf' tires. Even with loaded rear tires they spin easier tearing the yard up more and I find I have to use 4wd more often to prevent it. Although flipping a switch to engage the 4wd is much nicer than fighting with the lever on the CK. The FEL doesn't seem to lift that much more, even though it is spec'ed to lift twice as much. DK stalls easier. When I take my foot off the forward pedal... the tractor keeps driving forward. This leads to stalling often when moving piles of dirt and it is worse in winter moving snow. I have even pressed on the reverse pedal and the tractor keeps driving forward for a moment. I prefer the single pedal HST control of the CK vs the dual pedal of the DK. After 48 hrs, I keep pressing the wrong pedal and going in the wrong direction. I have damage to my tractor hut to repair due to this. The single pedal was much more intuitive to me. I feel the FEL is painfully slow compared to the one on the CK. When I move the FEL control to 'dump' the bucket... sometimes it works, sometimes it doesn't. I found the CK just generally more maneuverable than the DK. I put a Woods BH90x backhoe on the DK, it doesn't seem much more powerful than the Kioti BH that was on the CK. Between the DK upcharge and the Wood BH.. at the moment I feel I threw away $20k. The DK will be going in for its 50 hr service in the spring, I am really hoping some of these issues will be fixed then.
   / ck dk trade #17
I think your experience is very instructive.
I'm from the school that bigger IS NOT always better. I find it interesting how many folks advocate quickly buying a bigger tractor than may be needed.
In our household, we insisted that our tractor dealers let us live with the tractors, (use at our home for the weekend), we considered before making a final purchase decision. With a little friendly give and take we accomplished this and I feel we made better purchase decisions accordingly.
   / ck dk trade
Good post Jim, I never had a hst, so I won't be able to compare the ck35 shuttle. As far as tires are concerned you raise a good point. Which tires would be better for plowing snow, turf or industrial?
I really need a better loader, love the ck but the loader is lacking.
   / ck dk trade #19
I wanted a better loader as well, but the DK loader doesn't seem much better, it is definitely slower. I am hoping that the hydraulic pressure is low as both the loader and the backhoe don't seem as strong as I was expecting. I have no idea which tire would be better for plowing snow, I have never run turf tires. I run V-bar chains front and rear in the winter and as long as I don't stall it.. it is like a bulldozer. With the ice we occasionally get on our dirt road, chains are a must, not an option.
   / ck dk trade #20
If all three tires are compared in snow, without chains on any of them, most people have reported that turf tires offer an advantage. I don't think any of them are any good on slick ice without chains. I don't know what the problem is with IXLR8's machine, but my HST DK35se tractor does not run forward when you let off of the peddle, it stops immediately, it has never stalled, its loader response (cylinder response) is extremely fast, and it will lift every bit of its rated 1430 pounds to full height. The DK40se loader response will be a bit slower as shown in the specs, because the pump has only slightly more flow and the cylinders are bigger. To lift more you must have larger diameter cylinders, and of course they take longer to fill unless your flow rate is increased. My machines loader is so fast, that when I first got it and traded off my Kubota L3400hst I was concerned about how fast it was compared to the Kubota. It took me a couple of days to get used to it. The flow rate of the Kioti's pump is much greater than the Kubota, and the cylinders are only slightly larger, with about 300 more lbs of lift. So yeah, it is fast, real fast. But after using it for a while, I really enjoy it, and make use of the "snappy" loader response to get more work done in a shorter period of time.
So in summation, The DK40se loader response will be a bit slower than your CK. Example to raise the boom on the CK to full height is 3.9 seconds, to retract the bucket is 2.4 seconds. On the DK40se raise boom is 4.5 seconds but the retract bucket is only 2.1 seconds. So they have placed the largest cylinder on the raise boom. But the DK40's loader WILL lift over twice as much.
I can tell you this, Going from the 1100 lbs of lift on the Kubota L3400hst with the La463 loader to the Kioti DK35se with the KL351 loader is day and night difference. More than the 300 lbs published difference.
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
Loader Bucket (A59228)
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58216)
2014 MAGNUM...
2005 Chevrolet Impala Sedan (A56859)
2005 Chevrolet...
2014 MASSEY FERGUSON 5612 DYNA-4 TRACTOR (A59823)
2014 MASSEY...
iDrive TDS-2010H...
